Looking to know the best way and codec to use to convert some files from HuffYUV to DV. OS is Win7 x64 and in addition to VirtualDub I have Sony Vegas Pro 11.0 and Adobe Premier Pro CS6 available. I do not have any codecs other then what would be included with this software suite. I do have a Sony D8 Camcorder as a hardware based option as well.
I would be willing to purchase a low cost DV codec if it was worthwhile/necessary (say $50 or less).
Open your Huffyuv video in VirtualDub. Select Cedocida as the compression codec. If your source isn't bottom field first you must make it so. Ether use the Field Delay filter, or crop one scanline from the top and add one to the bottom. Save as AVI
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 07:31 -
What is Huffyuv?
By VideoFanatic in forum Video ConversionReplies: 11Last Post: 7th Jul 2012, 12:10 -
Batch convert HuffyUV and DV to "something" for smaller archive - HELP
By magillagorilla in forum Video ConversionReplies: 13Last Post: 22nd Dec 2010, 12:19 -
HD MPEG convert to Huffyuv AVI
By christianolovesvideo in forum Video ConversionReplies: 19Last Post: 7th May 2009, 19:00 -
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 14:30
