Results 1 to 18 of 18
There are some AAC mono tracks that may have some issues with ffdshow implementation of libavcodec. If you are using ffdshow, try to select 'libfaad2' instead of 'libavcodec' to decode AAC audio.
Otherwise you can try to switch from A2DSource to FFMpegSource in 'Preferences'/'AviSynth'. That may help to resolve the green screen too.
Bye -
@jovopros
hence your question should be: would it be possible to add an "automatic" option so that AVSTODVD detects whether the file has 25 fps or 29.97 fps and then converts the movie with the most similar DVD standard (PAL or NTSC)?
Yes, it is possible. I will put that in the ToDo list.
Bye
PowerDirector 9 Ultra 64 GREEN Screen Video with Audio
By JoRodd in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Mar 2011, 07:48 -
Converting Horse Feathers DVD to MP4 - audio plays too fast
By wkrick in forum DVD RippingReplies: 3Last Post: 7th Mar 2011, 18:04 -
AVStoDVD preview feature playes audio but no video (gray screen)
By granturissimus in forum Newbie / General discussionsReplies: 9Last Post: 12th Jan 2011, 15:27 -
Mov file with mono audio plays silently: fixed by opening Super
By aslaksen in forum Video ConversionReplies: 0Last Post: 7th May 2010, 19:35 -
Green frame at beginning of video, Why???
By Hittz in forum Newbie / General discussionsReplies: 9Last Post: 19th Dec 2008, 21:13
