Will it work? I plan to get one for better KH quality and such.
If you mean the hauppauge hdpvr than yes it will just fine. I'm assuming you want to record widescreen and progressive. You'll obviously need the component cables to do so. You can do 5.1 over fiberoptic as well.
But this is assuming the game you want to record is in widescreen and surround sound. Otherwise if its full screen with no surround sound and no progressive mode then you will just get the full screen basic i input.
Be sure to set the game to widescreen and surround sound in the setup menu before recording to capture in that mode. At least with guitar hero when I had a ps2 you had to switch it to widescreen manually in the setup menu. I'm not sure if thats true for all ps2 games or not. Some might be auto widescreen. But also check if they have 5.1 and set it up to that mode in the menu (ps2 games had digital surround right? I guess maybe not all but ones like god of war surely did right?).
By the way if its not hauppauge you are talking about as long as your capture device has component inputs you can record from the component cables from the ps2. Of course the ps2 is standard def so the best you'll get out of it is 480p.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 20:47 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 23:36 -
PS2 Mod Chipping...
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 20th Jan 2008, 16:38 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 12:12 -
Ps2 to Laptop
By sk8erkho in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2007, 12:31
