DOES ANYBODY KNOW A FULL-PROOF WAY OF FINDING, THEN REMOVING BAD FRAMES???
First download and run DivFix if that does'nt solve the problem.
Go to Divx-Digest and go to Virtualdub then download vdub_mp3_freeze
Then follow the instructions with this special vdub to check for bad frames.It will then identify the frames in a new file.You can then go back into the regular Virtualdub and remove the frames using the help section in vcdhelp.com
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
