  1. Greetings
    I was wondering if there was a way (plugin, software, setting, iFilter) to make windows explorer show A/V codecs in the details view.
    I'm looking for a column the likes of Audio Codec and Video Codec.
    MediaInfo adds pop-over commands; but that's not really what I'm looking for.
    I want something that will allow me, in the details list, to add those two details the same way as date; size, length... are included.
    Ideas?
  2. Not sure, but this is probably as much you can get:
    http://fav.me/d30e10g
  3. Thanks Hahahhaha, a great start and does help. Still need something for codec values though.
