I've finally gotten my workflow organized for working with these AVCHD MTS files. However, this merging of the MTS files when they exceed the filesize limit for a single file is a major time sucker! I'm currently using MTSMerger. Is there another program that will accomplish the merging faster? This is such a royal pain in the @ss.
	powerdirector10 if ur file is of same specification it will merge it very fast i mean it will do smart rendering of the material.
	If your computer specs are correct, the "file size limit" you talk about is actually likely a FAT32 issue rather than an AVCHD issue. I'm not aware of any file size limits for AVCHD. I don't claim to be an AVCHD expert, but for testing purposes I have used tsmuxer to create an AVCHD disc of about 23-24 GB in size. Last edited by jman98; 18th Oct 2012 at 08:38. Reason: typo
	The file size limit is imposed I guess by recording on the SDXC memory card. It appears to be a 2GB, or 11 and a half minutes at the highest quality. I discovered that Sony Vegas's Device Explorer will import and merge the files at the same time which is nice, but I think I also discovered a bug with it regarding the timestamp/filename of the files it creates so I'm trying to figure that one out now........
  How to merge multiple .mts files (canon HF) into one single .mts fileBy frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21
  Use .MTS files in Final Cut Pro while keeping original dates in the filesBy Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 17:21
  Adjust AVCHD mts file EXIF date-timeBy cheerful in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2011, 00:56
  HD Cam wrote .mts files to my flash card but put in another cam still mtsBy Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15
  Merging live firewire and saved AVI/video real-timeBy ruach in forum Capturing and VCRReplies: 0Last Post: 27th May 2008, 00:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
