Results 1 to 9 of 9
  1. I have a file downloaded from the web this is the media below.
        General
        Format                                   : WebM
        Format version                           : Version 2
        File size                                : 10.3 MiB
        Duration                                 : 6mn 30s
        Overall bit rate mode                    : Variable
        Overall bit rate                         : 222 Kbps
        Movie name                               : Untitled
        Writing application                      : Lavf53.13.0
        Writing library                          : Lavf53.13.0
        Video
        Format                                   : VP8
        Codec ID                                 : V_VP8
        Duration                                 : 6mn 30s
        Bit rate                                 : 76.6 Kbps
        Width                                    : 1 024 pixels
        Height                                   : 768 pixels
        Display aspect ratio                     : 4:3
        Frame rate mode                          : Constant
        Frame rate                               : 15.000 fps
        Bits/(Pixel*Frame)                       : 0.006
        Stream size                              : 3.57 MiB (34%)
        Language                                 : English
        Default                                  : Yes
        Forced                                   : No
        Audio
        Format                                   : Vorbis
        Format settings, Floor                   : 1
        Codec ID                                 : A_VORBIS
        Duration                                 : 6mn 30s
        Bit rate mode                            : Variable
        Bit rate                                 : 128 Kbps
        Sampling rate                            : 44.1 KHz
        Stream size                              : 5.96 MiB (58%)
        Writing library                          : libVorbis (Schaufenugget) (20101101 (Schaufenugget))
        Language                                 : English
        Default                                  : Yes
        Forced                                   : No
        Writing application                      : Lavc53.19.0
    I tried transcoding the file into MKV but no luck I could not get it to fix the seek issues:
        mkvextract tracks file.webm 0:file.ivf
        mkvextract tracks file.webm 1:file.ogg
        mkvmerge -o file.mkv file.ivf file.ogg
    I also tried fixing the indexes using mencoder but it got worse.
        mencoder input.mkv -idx -ovc copy -oac copy -o output.mkv
    I also tried Metorite
    Meteorite is MKV / Matroska file repair engine. That repairs MKV files and can repair MKV files still downloading from internet.
    I was able to seek but the video halts after moving the video sliders , the audio remains normal.
    Do you know other ways to fix the seek issues?
  2. I would try re-downloading the WebM file. It sounds like something got messed up during the transfer. If all fails again, perhaps you could download the video in another format, assuming one's available from wherever you got the WebM file in the first place.
  3. The WebM file is complete and encoding it into an MP4 solves the seek issues. However, I would like to know if I could fix the seek issues without re-encoding the file.
  4. DECEASED
    Jun 2009
    Heaven
    Seeking issues generally are caused by a bad MKV splitter.
    JMO, but since WebM sucks , I would (try to, at least) rewrap the VP8 stream in an AVI container, and then remux to MKV (by using the "V_MS/VFW/VP80" mode) with the Vorbis audio track.
  5. @El Heggunte
    Thank you for your response. May you please advice as to what tools will I be using in order to go about what you suggested?
    I have tried this though
    ffmpeg -i file.webm -vcodec copy file.avi
    I could now seek through my file. Question though, does the video gets re-encoded when I do this?
  6. Originally Posted by geocine View Post
    @El Heggunte
    No -vcodec copy means that video is just copied without any modifications
  7. Thanks @pandy,
    By the way, I want to use AAC for the audio
    ffmpeg -i file.webm -vcodec copy -acodec libvo_aacenc -b:a 128k -file.avi
    Whenever I use this I get this error below:
    I don't know if -b:a isn't really supported so I revise my command and do this:
    ffmpeg -i "file.webm" -v codec copy -acodec libvo_aacenc -ab 128k file.avi
    However I get an error regarding libvo_aacenc.
    I am using the latest Zeranoe FFmpeg build
    FFmpeg git-1a104bf 32-bit Static (Latest) (2012-10-10)
    According to the Readme . It was compiled with the configuration --enable-libvo-aacenc . so this shouldn't be a problem.
    Any idea guys?
  8. Perhaps Readme is not correct - i don't see libvo-aacenc on list
  9. Thanks pandy for helping out, I have solved the question above by fixing conflicting windows paths on my system.
