This one never happened to me before.
I'm trying to convert a DTS track to AC3, and I'm getting just the right channel.
I'm using AvsP, and I tried two scripts: one loading with ffaudiosource and another with nicdtssource.
The original DTS track sounds fine, so something is happening in the conversion.
I did not touch anything in the setup, and it's the same I used for hundreds of similar conversions. So I guess it should be something on the audio file which is different.
How should I proceed?
				Results 1 to 10 of 10
	Why are you trying to do this via a script in AviSynth? I would NEVER attempt to convert audio via AviSynth.
 Popcorn MKV Audio Converter and eac3to can both do this kind of conversion. I think ffmpeg may be able to do it too. There are probably other programs that can do it that I don't know about.
	I don't see why NEVER attempt audio conversion with Avisynth.
 In video they are the most transparent tools there are, and I don't see why that would be different for audio.
 Before using Avisynth I did use eac3to a lot, but I think Avisynth is better. OTOS, recently I tried to use eac3to again and I can't make it work.
	A man goes to the doctor. He says "Doc, every time I do this, it hurts. What can I do?" The doctor says "Stop doing that!"
 We already know what DOESN'T work - using AviSynth to do this. If you stubbornly insist that there must be a way to make AviSynth do this, then I'm done here and you're on your own.
 Your premise - AviSynth is great for video, therefore it must also be great for video - is flawed.
	Sorry, but I don't do anything stubbornly. I do stubbornly look for better ways to do things, so my findings on good audio results with Avisynth were empirical, not theoretical.
 Another thing I found is that many of the programs I was using before were implementing Avisynth developed plugins.
 I would happily be willing to try other program options. Eac3to, as I said, I have trouble to get it to work. It seems to stop and says "Script paused". I can't make it get out of that mode.
 My try at Popcorn didn't get me too far, as I would only want to process the audio file, an option I could not find on the program.
 OTOS, can someone tell what might be happening with the AvsP processing?
	It's possibly something to do with the channel mapping being messed up in the process (for reasons I don't understand). Something like the left front channel being swapped with the left rear channel or something similar. Are you mixing down to stereo or just converting multichannel?
 I use MeGUI occasionally for converting audio. It'll decode using NicAudio, ffaudioSource or DirectShow. If all else fails DirectShow usually does the job, assuming you have an appropriate decoder (ie ffdshow). With ffdshow decoding you can at least visually check the channel mapping and even change it if need be. Just make sure ffdshow's mixer doesn't default to mixing down to stereo unless you want it to (or disable it). You probably don't need MeGUI to do the encoding if you just open the video/audio using a DirectShowSource AVISynth script.
 Failing that, I use foobar2000 for converting quite a bit. It'll convert all the common formats and it'll play/convert the audio inside MP4/MKV/AVI files etc. You'll just need to manually downloaded the appropriate encoder and tell foobar2000 where to find it. You'll need the Aften encoder for AC3.
 ffcoder might be another program to try. I "think" it uses MPlayer for decoding so that's another decoding option. AnyVideoConverter does too (I think).Last edited by hello_hello; 18th Oct 2012 at 11:55.
	As long as it is user friendly...
 Many of these programs I have tried are not that easy to understand how do they work.
  Wrong Codec ??? (for DTS to AC3 conversion) Please help!By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 08:50
  DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problemBy SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 05:41
  Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50
  Weird problem during the DTS -> AC3 convertBy maciex47 in forum AudioReplies: 2Last Post: 6th Nov 2010, 10:40
  Convert 1080p to 720p with DTS conversion to AC3By El Duderino in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2010, 09:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
