I have rendered HDV an m2t file using Vegas 8.0c to a Cineform avi and have a resizing AviSynth script that will not load in to VirtualDub. It comes up with an error message "couldn't locate decompressor for format".
Can anyone tell me what might be going wrong and what I can do to resolve my problem?
Results 1 to 14 of 14
Do you have cineform installed ?
http://gopro.com/3d-cineform-studio-software-download/
What is your avs script ? -
AviSource() requires VFW codecs, not DirectShow codecs. Try DirectShowSource()? Vegas may have a private Cineform codec?
It does. That means it won't talk to other apps. You need to DL the free Cineform Studio which includes a general VFW codec.
Scott -
In another program (one that uses VFW codecs)? Yes, it should.
edit: if I understand you correctly and you haven't yet DL'd the Free Studio Cineform HD (VFW) codec, the only app that you have Cineform compatibility with right now is Vegas. So you could open it up in Vegas again, but until you DL the aforementioned, you won't be able to use it in other VFW-compatible apps.
Scott -
Thank you again Scott. I have a new problem now. I cannot not 'Select Platform' on the download page.
I can see all three options but the drop down tool is not working in Firefox or IE latest. If I submit it defaults to the first option (Mac) and I want the last option (PC). Unexpected but once I have solved this issue, I should be able to proceed so I thank you very much for your help. -
the gopro page doesn't work in firefox, chrome, or safari.
Thank you everyone. I installed Cineform Studio and imported the 50 GB HDV avi and resized it to SD. One minor problem, the SD avi is three times the size of the original file (150GB).
Oh yeah, thanks again. I used the Cineform codec then discovered that Vegas could not open the video element of the newer Cineform codec file I made with VirtualDub but I renamed the cfhd.dll file and then Vegas decoded the file and so I have made the DVD I wanted to make.
Thank you all again.
Should i use and avisynth script for Dv ?
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2012, 08:29 -
Lost ability to use Avisynth script to open .flv file with virtualdub.
By DaneClark in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 11:33 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47
