Been using Winavi All In One Converter for a couple of years now and just recently the "Fit to Single 4.3 Gb DVD" works maybe 50% of the time. The DVD file it creates is either too small (2.9 Gb or smaller) or too big (4.8 Gb - 9Gb). Anyone else experiencing this ?
	to finish that centence G just checked that out for you with Dragon Heart 6.44 gig result is 4.2 gig you have a setting in options to reset paramiters had it set output 3.4 and I much prefear gee wizz over o my
	I used WInAvi a couple of times for small projects. Works great. Like you have a couple small AVI files, put them through winavi, no hassle.
 For any serious project, it's unusable. You don't control the encoder and i don't think winavi itself really controls it's own encoder. Why the file is too big is probably because it doesn't handle (or doesn't want to handle) very low bitrates. Had the same problem with very long movies.
 Now i use ffmpeg + dvd authoring program.
  No sound upon conversion from RMVB to DVD using WinAVI Video ConverterBy kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 17:28
  avs (avi to avi) ends up out of sync ... winavi output file too bigBy mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56
  anybody tried winavi video converter 7.7 with ffdshow?By Nokiamania in forum SubtitleReplies: 0Last Post: 14th Aug 2009, 19:11
  How to: Making a DVD with WinAVI Video Converter.By reboot in forum User guidesReplies: 74Last Post: 29th Nov 2008, 10:59
  HELP svcd2dvd output too big for a dvdBy scaffers in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Nov 2008, 14:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
