  1. Hi guys i was struggling to recover one tape that is damaged ( it look like it was jammed couple of times or handled without care )
    I used median/3 capture but because the errors are on the same place it didn't solve the problem i also searched videohelp and doom9 for any script ( i found mostly based on mvtools and masktools but they were useless). Another problem is that the broken frames are 10-20 in a row so fiddling with rx and changing bad frames and interpolation produces some weird artifacts.
    I want to fix this or delete the frames but without screwing the audio ( in the bad frames there is conversation between people that will be cut, if i do just plane cut of the bad frames in vdub for example)
    So is there any masking fixing or deleting that i can do so the audio still plays in sync
    The bad examples
  2. You can't just delete the video frames and keep the audio. You need something to fill that space - you have to replace the video frames with something - either blank frames, or duplicate frames e.g. badframes.dll
  3. is this plugin i couldn't find it i also tried bad frames script with no avail
    poisondeathray i uploaded example
  4. Originally Posted by mammo1789 View Post
    http://avisynth.org.ru/badframes/badframes.html
    badframes just replaces with duplicate . So picture will be held static for those 20 frames .
    Or you can replace with a black frame (e.g. use trim and aligned splice)
  5. Originally Posted by mammo1789 View Post
    ok, for this one you can repair it (semi)-manually with other compositing and motion tracking programs like after effects, mocha. What you do is motion track parts of good frames and mask or "cover up" the bad parts of frames .
    It's a more work than using somefilter() , and the requirement is you need sections of good frames to copy from. Also, it only works if the stuff copied from is static or low motion . When those requirements aren't met, you actually have to photoshop certain key frames to derive information from
  6. I have after effects but i never fully understand it or used it much other then simple animations or intros
    thanks pois but i will have to learn the masking and motion tracking and i know it will take me some time ( which i don't have at a moment ), so i can use it properly until that time i think pirej had some pretty good scripts i will try to dig some old treads because he is not very active recently i used them some times but they usually work if the bad frames are just 1 or 2 in a row and here on the video i have sometimes as much as 30 or more
