Hi, I have two camcorders one of them records in 25 FPS and the other one in 29 FPS. I want to edit a 2-cam footage using these two cameras, but I will use as main audio the sound from the camcorder that records at 29FPS. The other camcorder's sound will be used as a reference. My question is: If I extract the audio from the 29FPS Camcorder and stitch it to the video with 25 FPS, will the audio be synced? If not, how can I fix this problem and convert the sound to fit with my 25FPS footage? Thanks a lot.
Audio doesn't have an FPS
The 2 audio tracks should approximately be in sync, if they are not genlocked to the same signal you can get audio drift. Over short durations it might not be noticable, but audio drift over long durations will be noticable . To check, you can line up the audio tracks and compare the waveforms in an audio editor or NLE - they should be fairly close -
If the audio drifts as you said, is there any way to fix it? Thanks
If it drifts, you have to manually sync it in an editor. This can be very painful, or if you luck out , it might be a breeze
Audio length and video length must be the same - if audio length is same as video length and same on both recording i see no source for audio drift unless there is somewhere error. Or in other words - both audios shall be perfectly exchangable when both video (and audio) tracks have same play time.
The problem the OP is going to have is that in order to edit the 2 cameras' footage together, ONE of those camera's video is going to need a framerate conversion (FIRST). Depending upon how the conversion goes, it could necessitate stretching/shrinking of the time (plus, pitch correction if desired/needed) which makes the whole job a LOT more complicated.
You really should re-think your whole 2-camera setup and try to go with 2 cameras that use the same system (either PAL/25 or NTSC/29.97) - maybe too late for this shoot, but not for future shoots. If you live in Manchester, UK it should be PAL, if Manchester, N.H., USA it should be NTSC...
Scott -
If i understand correctly - those two cameras are intentionally different and they will be used to comparison (one of them as a reference) not sure on this however - my point is that if they (camera's) recording at the same time moment then audio same length can be used independently (not sure why but it is up to the OP)
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
multicamera video montage with different source fps and video formats...
By foler in forum EditingReplies: 2Last Post: 16th Feb 2009, 05:19 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
