wait a second, that lets us put an entire dvdrip onto 1 vcd??
Results 451 to 460 of 460
Massimo N. Aldorasi
when it should be converting, how come i get the converting process but instead of the frames converting it just says "Analyzing" instead?!?!?!
EDIT: the destination file is where i set it to when i am encoding but when i abort the encoding, the output file disappears.....is it suppose to completely encode for the output file to stay there???Massimo N. Aldorasi -
It suposed to say that !it just says "Analyzing"
on the 1st pass its analyzing your file
on the 2nd it encodes. -
that somewhat stinks lol...but i can live with that i guess
Alright people, some very, very strange news here!
I've been trying to follow this guide step by step for DAYS, and the output file, although with the correct bit rate when analyzed (900 in my case), always ended up the same size!!!
For one of those reasons the only computers can give you (no reason at all) I downloaded the free version of TMPGEnc and IT WORKED!!! I've been using TMPGEnc Plus.
Of course I thought that the default settings were the real reason one was working and the other was not. Ok, I copied EVERY SINGLE setting from the version that could do this to the Pus version... DOES NOT WORK!
Well, the problem is solved. Now, when I want to fit a movie onto one VCD, I use the old version. Ironic.
Just out of curiosity: does anyone know why TMPGEnc Plus is not doing it right?
well, what's happening here is the exact opposite: TMPGEnc Plus 2.59 has the bug and TMPGEnc 2.52 works fine...
Ok, guess I'm kinda uninformed then!
Thanks anyway, now I'm happy with my VCDs!
TMPGEnc 4.0 XPress Guide
By Felo in forum Video ConversionReplies: 2Last Post: 22nd Oct 2009, 01:21 -
Newbies first post - FInalcut + what?
By fontenele in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2008, 18:34 -
Fitting more clips into TMPGEnc DVD author. Anybody know?
By hellfire45 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2008, 17:12 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 21:22
