Used only the fitting the movie on one disc part...works like a charm.
I have a KLH digital KD-1220
Results 421 to 450 of 460
i have a movie file I want to burn to a 700mb/80min disk
Here is the files spec:
774 MB
kvcd encoded
mpeg movie clip (was D/L)
When I open it in nero and see if I can overburn..the message that asks if you want to overburn does not come up. So Iit wont let me burn it
I followed your steps with the non-complient...and I ended up with a 995 MB file...?
What did I do wrong? normally when I d/l something it's ready to be burned or simply needs to be converted. But I can't figure out what I am doing wrong.
I use TMPGEnc Plus 2.59.47 and nero 6.0.0.28 with all plugins, Thanks
PLEASE HELP PLEASE - 12/11/03 @ 4:36pm -
Just a bit off topic but refering to the above poster....
Where do you get your ready mpeg endoded films/videos from?
all i can seem to pick up is DIVX ones.....great quality and normally not to much lowering of the bitrate is needed....
Nick -
just gotta know where to look...sorry, if not being more specific.
i like divX, even more then mpeg. but I rather save the trouble of converting to make vcd's. pm me if you want more info. -
TMPGEnc 2.59 had a bug which always encoded VCD's at the standard 1150 Kbps bitrate even if you selected something else. Try a different version. 8)Originally Posted by oscar"Art is making something out of nothing and selling it." - Frank Zappa
that would explain my problem!!! I know something was wrongOriginally Posted by ZippyP.
Thanks for the info...
I waiting about 3 days to finally be able 2 post a comment...THANK-U so much 4 the guide!!! The first time I used it, I totaly missed seeing the MPEG-1 Video-CD (non-standard) option, so of course it didn't work. Thanks 2 the forum, I was able 2 correct my oversight and the settings work just fine! I was about 2 put "The Matrix" on one disc and it works just fine on both of my Daewoo (yeah cheap) DVD players
Peace and Stay Wild,
JP -
Dear friends, no matter what I do, TMPGEnc, I stoped using the latest version and tried v2.8 the movies always end up being 1GB. And when I use de VCD (non-standard) Roxio's Easy CD says System Clock error. Please help.
Dear friend...U have 2 use "non-standard" all of the time 4 this template 2 work. Use Nero or VCDEasy 2 burn Ur VCD's. I believe it's been posted here that Roxio Easy CD Creater will not burn "non-standard" VCD's
JP -
JP Thanks!! That's it, how much time I wasted trying to burn with Roxio's, I installed Nero and everything wen OK
Thanks!!!!!!!! -
Why does TMPGEnc Plus 2.5 crash everytime I load a d2v file???
Do I need something else besides creating an One Disc VCD template? -
2nd Link below.Originally Posted by lndtf
"Art is making something out of nothing and selling it." - Frank Zappa -
Could you be more specific???
I have DirectShow Multimedia File Reader to priority 2 in VFAPI plug-in and there are DVD2AVI.vfp and TMPGEnc.vfp in the same folder. What else do I need? -
Hi everyone. I am a new guy who has a few problems.
1. I have version 2.5 but I can't seem to find the Wizard folder that is mentioned in the tutorial.
2. I have a video file I want to make into a VCD. It is about 700mb in size. I can't seem to get it to finish with a size under 1GB with out turning quality of the video to garbage.
3. Do you think I should just buy a DVD burner and get a program that turns AVI to DVD?
Well thanks for any help I get. -
The wizard is not a folder, it is the interface window which opens up when you first start TMPGEnc, the "Project Wizard."Originally Posted by BillNye
The unspecified "video file" that is 700 MB is converted into a VCD mpeg of more than 1 GB. Since VCD is about 10 Mb per minute that would tell me that your file is larger than 100 minutes. That's just the way that VCD works, and VCD is pretty crappy as it is without trying to make it any smaller by lowering the bitrate.
You can try to make a DVD which would be much better quality than VCD or you can go for SVCD (if your DVD player will play it) which is pretty good as well. TMPGEnc is what I use for converting to mpeg."Art is making something out of nothing and selling it." - Frank Zappa -
Thanks. The file I am trying to make to a VCD is a 700MB version of the movie Swordfish. I think it's just way too big.
I decided I'll just make Simpsons episodes into VCD's and burn the movies onto DVDs. Thanks for the help.
If you care about quality: www.kvcd.net
If not, then this guide should work fine.
- Icarus -
kvcd = if u want superior quialty, it takes so much time, with teh using scripts and shit, but if u jus use the template in tmpg it looks no better IMHO
or atleast it was in July wen i used to post
cyaJordan Ennis -
When I go to the last part to select the size of cds, TMPGnc keeps CD-R 74min as the first choice which I always have to roll down to CD-R 80min. Is there any way I can have TMPGnc to show CD-R 80min as the first choice? Thanks
You need to edit the template file with notepad, though I'd save your own custom template and edit that one so you always have the original as a reference and you don't accidently overwrite your changes installing a newer version of TMPGEnc. The line for media size should read...
Code:MPEG.WizardTargetMedia = MPEGConfig_TargetMediaType_CD_80min
This guide really looks great! Unfortunately I didn't get very far. When I tried to open the template VideoCD (NTSC) in TPGEnc, I got the error "Invalid Stream Format". I've searched the forum and found no reference to that error message. Any suggestions. I'm pretty much a newbie, but I have used TPGEnc quite a bit, but I've never tried to customize the settings. Thanks for any help anyone could give.
Lville -
Ah, what the hell, here's the best template I've come up with for fitting a movie on 1 CD. Feel free to rip it apart at your leisure. xVCD NTSC FILM
Code:object TMPEGConfigFile MPEG.Text = '' MPEG.WizardCategoryName = '' MPEG.WizardSubFormatName = '' MPEG.WizardCaption = '' MPEG.WizardDescription = '' MPEG.WizardTargetMedia = MPEGConfig_TargetMediaType_CD_80min MPEG.WizardAutoCalcVideoBitRate = False MPEG.WizardAutoChooseList.EnableVideoSize = False MPEG.WizardAutoChooseList.VideoSize = <> MPEG.WizardAutoChooseList.EnableVideoGOP = False MPEG.WizardAutoChooseList.VideoGOP = <> MPEG.OutputStreamType = MPEG_OutputStreamType_System_VideoAudio MPEG.OutputStreamType_ReadOnly = False MPEG.Video.StreamType = MPEGVideoEncoder_StreamType_MPEG1 MPEG.Video.StreamType_ReadOnly = True MPEG.Video.Width = 352 MPEG.Video.Width_ReadOnly = True MPEG.Video.Height = 240 MPEG.Video.Height_ReadOnly = True MPEG.Video.YUVFormat = 1 MPEG.Video.YUVFormat_ReadOnly = True MPEG.Video.DC_prec = 0 MPEG.Video.DC_prec_ReadOnly = True MPEG.Video.VideoEncodeMode = MPEGVideoEncoder_VideoEncodeMode_Progressive MPEG.Video.VideoEncodeMode_ReadOnly = False MPEG.Video.FrameRate = 4 MPEG.Video.FrameRate_ReadOnly = True MPEG.Video.AspectRatio = 12 MPEG.Video.AspectRatio_ReadOnly = True MPEG.Video.RateControlMode = MPEGVideoEncoder_RateControlMode_VBR_2PASS MPEG.Video.RateControlMode_ReadOnly = False MPEG.Video.MaxBitRate = 1856000 MPEG.Video.MaxBitRate_ReadOnly = False MPEG.Video.MinBitRate = 64000 MPEG.Video.MinBitRate_ReadOnly = False MPEG.Video.MinAvgBitRate = 400000 MPEG.Video.MinAvgBitRate_ReadOnly = False MPEG.Video.CBR_BitRate = 1152000 MPEG.Video.VBR_MultipassVBRAlgorithm = MPEGVideoEncoder_MultipassVBRAlgorithm_MultipassCQ MPEG.Video.VBR_AvgBitRate = 1152000 MPEG.Video.VBR_MaxBitRate = 1856000 MPEG.Video.VBR_MinBitRate = 64000 MPEG.Video.VBR_MaxPassCount = 2 MPEG.Video.VBR_Quality_P = 0 MPEG.Video.VBR_Quality_B = 20 MPEG.Video.VBR_EnablePadding = True MPEG.Video.MVBR_MaxBitRate = 1856000 MPEG.Video.MVBR_MinBitRate = 64000 MPEG.Video.MVBR_Quality_P = 0 MPEG.Video.MVBR_Quality_B = 20 MPEG.Video.MVBR_EnablePadding = True MPEG.Video.AVBR_Quality = 80 MPEG.Video.AVBR_MaxBitRate = 1856000 MPEG.Video.AVBR_MinBitRate = 64000 MPEG.Video.AVBR_EnablePadding = True MPEG.Video.CQ_Quality = 80 MPEG.Video.CQ_Quality_P = 0 MPEG.Video.CQ_Quality_B = 20 MPEG.Video.CQ_MaxBitRate = 1856000 MPEG.Video.CQ_MinBitRate = 64000 MPEG.Video.CQ_EnablePadding = True MPEG.Video.VBVBufferSize = 40960 MPEG.Video.VBVBufferSize_ReadOnly = True MPEG.Video.GOP_SeqHeaderInterval = 1 MPEG.Video.GOP_SeqHeaderInterval_ReadOnly = True MPEG.Video.GOP_I_FrameCount = 1 MPEG.Video.GOP_I_FrameCount_ReadOnly = False MPEG.Video.GOP_P_FrameCount = 5 MPEG.Video.GOP_P_FrameCount_ReadOnly = False MPEG.Video.GOP_B_FrameCount = 2 MPEG.Video.GOP_B_FrameCount_ReadOnly = False MPEG.Video.GOP_BitStreamForEdit = False MPEG.Video.GOP_BitStreamForEdit_ReadOnly = False MPEG.Video.GOP_MaxFrameCount = 18 MPEG.Video.GOP_MaxFrameCount_ReadOnly = False MPEG.Video.QuantizeMatrix_Intra_ReadOnly = False MPEG.Video.QuantizeMatrix_NonIntra_ReadOnly = False MPEG.Video.Profile = 4 MPEG.Video.Profile_ReadOnly = False MPEG.Video.Level = 8 MPEG.Video.Level_ReadOnly = False MPEG.Video.VideoFormat = 2 MPEG.Video.VideoFormat_ReadOnly = False MPEG.Video.DisplayWidth = 0 MPEG.Video.DisplayWidth_ReadOnly = False MPEG.Video.DisplayHeight = 0 MPEG.Video.DisplayHeight_ReadOnly = False MPEG.Video.MotionSearchSpeed = MPEGVideoEncoder_MotionSearchSpeed_Slow MPEG.Video.MotionSearch_AlwaysHalfPel = True MPEG.Video.UseFloatDCT = False MPEG.Video.QuantizeMode = True MPEG.Video.QuantizeModeVal_Intra = 35 MPEG.Video.QuantizeModeVal_NonIntra = 35 MPEG.Video.YUVBasicYCbCr = False MPEG.Video.QuantizeMatrix_Intra = { 081013161A1B1D22101016181B1D222513161A1B1D22222616161A1B1D222528 161A1B1D202328301A1B1D202328303A1A1B1D22262E38451B1D23262E384553} MPEG.Video.QuantizeMatrix_NonIntra = { 1011121314151617111213141516171812131415161718191314151617181A1B 14151617191A1B1C151617181A1B1C1E1617181A1B1C1E1F1718191B1C1E1F21} MPEG.Audio.StreamType = MPEGAudioEncoder_StreamType_MPEG1_Layer2 MPEG.Audio.StreamType_ReadOnly = True MPEG.Audio.SamplingFrequency = 44100 MPEG.Audio.SamplingFrequency_ReadOnly = True MPEG.Audio.ChannelMode = 0 MPEG.Audio.ChannelMode_ReadOnly = False MPEG.Audio.CantUseMono = False MPEG.Audio.BitRate = 128000 MPEG.Audio.BitRate_ReadOnly = False MPEG.Audio.CalcCRC = False MPEG.Audio.CalcCRC_ReadOnly = False MPEG.Audio.OriginalFlag = False MPEG.Audio.OriginalFlag_ReadOnly = False MPEG.Audio.CopyrightFlag = False MPEG.Audio.CopyrightFlag_ReadOnly = False MPEG.Audio.PrivateFlag = False MPEG.Audio.PrivateFlag_ReadOnly = False MPEG.Audio.EmphasisType = 0 MPEG.Audio.EmphasisType_ReadOnly = False MPEG.System.StreamType = MPEGSystemEncoder_StreamType_MPEG1_VideoCD_Illegal MPEG.System.StreamType_ReadOnly = True MPEG.System.EnableCommentText = False MPEG.System.CommentText = '' end -
Hello,
I Have Tryed This Guide several times, But Yet i always Get Lousy quality Video's.
Now i see alot of ppl say i get excellent Quality But after doing the same Movie 10 times, I can't get it to come out, Picture has alot of blurr in it, The sound is okay, But the video isnt even close to vhs standards,
My Settings are Exactly what this Guide States ( except i messed around with the Bitrate highering it and lowering it to get better quality ) even when i tryed 1000 Bitrate the picture still was same any clues? -
Bondiablo: Where do I put the code? Is it between these two?
MPEG.Text = '' -
Put it where your current template says "MPEG.WizardTargetMedia...." I posted an entire template above, you can see it there as well.
Hello I used a guide On here And Tryed to make a One cd vcd, Looked Like crap, 86 min movie,
so then i compressed a Divx, And Picture and sound was perfect,
Now Using exact settings for vcd the Picture still looked Blurry and crappy,
Any Clues Why The divx Is Picture Perfect and the vcd Looks Like Sh|t? -
Well After Not getting any replys All i can asume is you Ppl have LOW Standards Cause i Did this Several times With a 86 Min Movie with over 1000 Bitrate, The Picture Was Fuzzy, The credits were Blurry, In dark scenes there Was Gray boxxes and throuout the Movie it Jumped, And the Faces or images went in and out of focus, This was a direct from dvd convert, Played the rip file picture was perfect, I see ppl saying Can't tell the diff from the dvd or the vcd and thats at 900 br im using over 1000 and i seen Better Screening video's, I used The guide to a tee, done it several times over and No change, Ill stick to spending 40 bucks for 25 dvd +r least they look good,
Dear Bondiablo: I have replaced your template and saved but it doesn't stay, so I still get into the 74min. Could you please let me know that I did anything wrong? Thank you. Better Life
TMPGEnc 4.0 XPress Guide
By Felo in forum Video ConversionReplies: 2Last Post: 22nd Oct 2009, 01:21 -
Newbies first post - FInalcut + what?
By fontenele in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2008, 18:34 -
Fitting more clips into TMPGEnc DVD author. Anybody know?
By hellfire45 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2008, 17:12 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 21:22
