I can't get the same version of CladDVD XP 1.3. The link is dead...help!
Results 361 to 390 of 460
Well don't expect to cause this post was started one whole year ago at march 31 2002 so do a search on google or something
This is a very informative piece and I learned a lot......Is there a similar form on this site that would "walk" me through the process of converting my old VHS tapes to DVD? I have no problem getting my unedited tapes to harddrive but a 98 min. tape is too large for one DVD disk........I know it will fit but nowhere can I find a solution to converting a lesser quality tape so it will fit. I am using a Sony 500 ax and MyDVD software......I have a large harddrive on a new Compaq with passthrough on a Canon 65 mc......
Thanks for any direction/ help.
Jack Carter -
I finally got this and have 3 movies backed up now. I am able to play the vcd's on my standalone dvd player and thats awesome! By the way, my standalone is an RCA model # RC524OP.
I am having a problem backing up Red Dragon. Everything goes well with ripping and frameserving. I get the two files I need for tmpgenc, but I did a test of a small part of the movie, and when its played, you can hear the actors talking in the background and a person talking about the movie. The video part is good. I used English ac3 2h. I played the dvd to see if thats how it played and it doesn't. It plays normally without the extra talker. What is this and how do I get rid of it? -
I am having a little problem with TMPGEnc v 2.5.
When I make my video profile and I name it and try to save it in the Wizard directory, there is no wizard directory.
If I just put it in the Template directory with all the other templates my saved Template does not appear.
I am using the shareware version of TMPGEnc.
Thanks Brad -
I have TMPGEnc Plus 2.58 and no wizard folder. I put all my templates into the template folder and they end up under the heading "Other" when I open the wizard.Originally Posted by BradBo"Art is making something out of nothing and selling it." - Frank Zappa
This article is great. Burned Almost Famous (123 minutes) on a VCD. Slightly bad quality and the picture is stretched so they all look anorexic, but still very convinient.
IMHO, 123 minutes is a bit much for 1 disk.Originally Posted by miss_universe93
Be sure to select Full Screen (keep aspect ratio) under video arrange method, that way the video won't be shrunk or stretched.
8)"Art is making something out of nothing and selling it." - Frank Zappa -
Great thanks to site. Got my Bond (Die Another onto one CD).
Used Cladvd.net ver 3.3 & TMPGenc Plus 2.5. However in TMPGenc when I tried to use 2 -Pass VBR it would complete the first pass 50% then it would fail with a floating point error. Any idea's. When I changed to CBR it worked fine.
plays on my Alba103 & Mico DVDA980s.
I found a m2v.vfp plugin do I put this into TMPgenc directory and then select via VFAPI plugin.
Almost forgot main reason on my Bond movie I selected main Audio track but when they used subtitles in the film this was not on my copy how do I find this and add for next time
You can NOT use tmpgenc 2.59 with this guide. It has a bug, so the resulting vcd keeps getting the same (too big) size.
Damns, it took me some time to find that out !
/jim -
Here is a question.
Lowering the bitrate decreases the quality of your data.
But what happens if I have a file downloaded with a bitrate of 1150 and I increase it to say, 1500?
I know that the quality of the picture will stay the same and that the amount of space used will increase, but do I gain anything in say, eliminating jerkiness or anything?
Cheers
Leensypops[/quote]
This is a guess but.. No. It will not help. Rule of thumb is: crap in, crap out.
BUT, regarding "jerkiness". I (accidentally) used the "Normal" setting in tmpgenc, for "Motion search precision" and it was very jerky. Here is my definition of jerkiness: When a man was walking down the street, the camera followed him, then the image "froze" for a split-second, and then it resumed action again, but the man was a little further down the street, and we didn't know how he got there.
I re-encoded, this time with the setting I usually use "Highest quality( very slow)" and the man walked smoothly down the street.
I encoded from avi to vcd.
/jim -
yo
for the jerkiness
ok does the audiop stay steady tho>>
cuz i make all of mine in normal
and sum, not all
jerk every once in a while
like it will jump pictures etc. but the audio stays steady
its like the peopel are in fast motion for liek 5 secs, then it resume normally
hmmJordan Ennis -
look if anyone is having trouble with choppy audio its nothing wrong all you have to do is make 2 samples i would rather do an MPEG2 than MPEG1 ok and do this try to do this either 29.97 and 23.97(29.97 fps internally) burn them on cd rws and test them believe me this will solve your audio problem.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
look if you want good quality videos on one cd-r i would prefer go to www.kvcd.net and download this template SKVCD NTSCFilm
352x480
Avg. 120 minutes
per CD.
its like CVD but its KWAG style all i change on this template is i use 48000 khz for audio and i use motion estimate search presison cause it looks good anyways.An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
If in wrong forum please point the way. Anyway by following the various guides I getting the hang of most problems, execept this one. Where are how and with what program can I copy/rip my dvd's which have subtitle text within the main program. I'am not talking about subtitles which you switch on or off. (example alien speaking in Star Wars, Or the subtext used in The Mummy) I'am able to use Claddvd.net, DVD Decrypter, TmpGenc.
From which a get perfect moives and soundtrack but the formentioned text is missing
i dont get it??
u are trying to rip a movie with teh subtitles in the movie?? like starwars?? etc???
if so u do it like a normal movie using clad etc.....
i thinkkkk
cuz its part of the original movieJordan Ennis -
Sorry if i'am not explaining myself . If you take The Mummy dvd in the begining sequence they speak ancient egpytion which is shown in english via subtitles but the rest of the film goes on as normal with the subtitle coming on for the ancient egytion. Now when I rip this movie and the ac3 sound track and play the movie back this is missing. what i'am I doing wrong. I know it must be simple but i'am missing the point.
wellll
thats very weird
i understood it
but isnt that subtitle part of the movie
eitehr the dvd is fucked
or ur missing it, or it got cut out
i cant think of anythung else
peaceJordan Ennis -
Is there anything out there that can tell me what the bit-rate (not frame rate) of a downloaded file is?
Lino -
yeh
look at the tools section of this website
i cant remember what its calledJordan Ennis -
Had to stop by and thank the person who made that guide. It fuken works!!! I managed to fit a Matrix Reloaded SVCD that I converted to a VCD with good quality (740 bitrate, 112kb audio) on one disk, and even was able to add chapter selection to it by turning it into a Bin using VCDEasy, and burning the image using Nero.
I wuv joo guys!!!
Oh, and I'm using a Sony stand-alone DVD Player.... Poop. I forgot the model number, but I know it's from last year.
I have dvd decrypter and rip movies using that, but when i try and encode them using tmpge, it tells me that there is no file there to encode. I know very little about the whole deal, can someone point me in the right direction. All help is greatly appreaciated.
TIA
NitaThis is gonna be great, we can stay up late swapping stories and in the morning, im making waffles... -
Hi I have tried following the instructions step by step for the one disk vcd format using TMPEGen and every time it ends up about 1gig or about 1.1 and I have it set at mpeg 1 vcd non-standard under the system tab and still no luck any idea what i am doing wrong??
Originally Posted by wellsy
Damm thing wrong version of TMPEGEnc version 2.59 will not work with this guide -
Hi! I am hoping that somebody can help me. I am a newbie to the whole world of computers so is there someone who can walk me through the process of making a dvd and what I need to download so I can do one I have already downloaded a movie on my hard drive but what do I do after that. I have tried to understand the guide but now I can't use claddvd XP so whats next. Please help the movie I have downloaded is bad Boys II (CTP) divx TS
TMPGEnc 4.0 XPress Guide
By Felo in forum Video ConversionReplies: 2Last Post: 22nd Oct 2009, 01:21 -
Newbies first post - FInalcut + what?
By fontenele in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2008, 18:34 -
Fitting more clips into TMPGEnc DVD author. Anybody know?
By hellfire45 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2008, 17:12 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 21:22
