Video
ID :
Format : ???
Format/Info : ???
Format profile : ???
Format settings, CABAC : ???
Format settings, ReFrames : ???
Codec ID : ???
Duration : ???
Bit rate : ???
Height : ???
Display aspect ratio : ???
Frame rate mode : ???
Frame rate : ???
Color space : ???
Chroma subsampling : ???
Bit depth : ???
Scan type : ???
Bits/(Pixel*Frame) : ???
Stream size : ???
Writing library : ???
Language : ???
Default : ???
Forced : ???
Audio
ID :
Format : ???
Format/Info : ???
Codec ID : ???
Duration : ???
Source duration : ???
Bit rate mode : ???
Bit rate : ???
Maximum bit rate : ???
Channel(s) : ???
Channel positions : ???
Sampling rate : ???
Compression mode : ???
Stream size : ???
Source stream size : ???
Language : ???
Encoded date : ???
Tagged date : ???
You don't ask much, do you?
What do you mean by "smaller file size"? A lot of noobs here expect to get a 700 Mb file (or even smaller) with no quality loss from a dvd or br. Not gonna happen, but they get snippy if you try to tell them that. Kids.
What are you ripping and encoding? It's a lot easier to get good results from a br than a dvd. It's much more fine grained to begin with.
Have you tried reading any of the guides elsewhere on this site?
The h.264 codec is the best one re. quality v. file size at the moment. But it can get pretty complex, in ways not hinted at by what you posted from mediainfo.
There are a number of good h.264 encoders. A lot of the good ones recommended here are fine for real video geeks (I'm fair to middling there) but not really suitable for noobs. They dump you straight into all the encoding options. They are excellent but they're complicated.
I'd suggest handbrake (or vidcoder, which is the same thing with a different interface) if you don't know what any of that stuff means. It has the best power/ease of use factor of any encoder I've seen.
Use constant quality mode, high profile, enable 8x8 DCT in the advanced options page. You cannot get good quality without the last 2 items. From there try advanced stuff.
Read the handbrake docs. They're excellent. Also the avidemux wikis. Don't expect serious video geeks to explain everything to you. -
*****************************THE PERFECT SETTING*****************************
>>>>>>>>>>>>>>>>>>>>>>>>>>1h 19mn - 352 MiB<<<<<<<<<<<<<<<<<<<<<<<<<<<<
General
Unique ID : 207715591631906002270461697281892514353 (0x9C44915A4ACE8E6D8FE9CE04FBAF7A31)
Complete name : *****/Tımarhane.2012.MKV.TR.mkv
Format : Matroska
Format version : Version 2
File size : 352 MiB
Duration : 1h 19mn
Overall bit rate : 623 Kbps
Movie name : Tmrhn 2012 DVDRip TRDUB XviD-HDM
Encoded date : UTC 2012-10-14 21:57:33
Writing application : mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 19mn
Bit rate mode : Variable
Nominal bit rate : 525 Kbps
Maximum bit rate : 25.0 Mbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.073
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 /
trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 /
constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 /
rc=2pass / mbtree=1 / bitrate=525 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 19mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Default : Yes
Forced : No -
*****************************THE PERFECT SETTING [2]*****************************
>>>>>>>>>>>>>>>>>>>>>>>>>>1h 41mn - 325 MiB<<<<<<<<<<<<<<<<<<<<<<<<<<<<
General
Unique ID : 181100337373922991699132901756385574872 (0x883EA80139D99773CFA7D71E78CF3FD8)
Complete name : ***\Cakallarla.Dans.2010.x264.strannqe.mkv
Format : Matroska
File size : 325 MiB
Duration : 1h 41mn
Overall bit rate : 448 Kbps
Writing application : HandBrake 0.9.4
Video
Format : AVC
Format profile : Main@L3.0
Format settings, ReFrames : 2 frames
Duration : 1h 41mn
Nominal bit rate : 283 Kbps
Width : 672 pixels
Height : 384 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.044
Writing library : x264 core 79
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=283 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 41mn
Default : Yes
Forced : No -
@matraxx22
have a look here, you may be interested:
https://forum.videohelp.com/threads/350113-X-QuaSaT-automatic-x264-settings-quality-spe...%28download%29
MKV,MP4,AVİ to HD AVİ
By Hallyu Sarang in forum Video ConversionReplies: 16Last Post: 5th Aug 2011, 13:09 -
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:31 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 07:14 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 18:05 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 23:36
