how do i deinterlace video that I've encoded with Format Factory?
specifically H.264 MP4's with AAC Audio at 1080p.
the issue im having is that when i upload videos like this one: http://www.youtube.com/watch?v=YDAhp8SAzq4&feature=youtu.be
to youtube, it adds a second video at the end with no audio. I'd prefer if this didnt happen
MediaInfo:
General
Complete name : C:\Users\ColbyB\Desktop\coversions\big.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 173 MiB
Duration : 1mn 29s
Overall bit rate : 16.1 Mbps
Encoded date : UTC 2012-10-12 22:50:35
Tagged date : UTC 2012-10-12 22:50:37
Writing application : mp4creator 1.6.1d
Video
Format : AVC
Format profile : High@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 1mn 29s
Bit rate mode : Variable
Bit rate : 15.8 Mbps
Width : 1 920 pixels
Height : 1 088 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.974 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.316
Stream size : 170 MiB (98%)
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 29s
Source duration : 1mn 29s
Bit rate : 265 Kbps
Maximum bit rate : 294 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 2.88 MiB (2%)
Source stream size : 2.88 MiB (2%)
Language : English
Encoded date : UTC 2012-10-12 22:50:37
That's strange. But it's not any interlace issue.
You could try use the youtube editor to cut the last part. https://www.youtube.com/editor -
According to MediaInfo your video is progressive not interlaced, ie nothing to deinterlacehow do i deinterlace video that I've encoded with Format Factory?
I don't know much of the behaviour of uTube but according to the specs the only transgression I see at a first glance is that your video is actually 1088p not 1080p. How uTube reacts to this I've no idea.Scan type : Progressive -
yeah i think its a dead case. i can't quite figure out what its doing that. probably has to do with the conversion to FLV
Problems with Format Factory
By wurm7467 in forum Video ConversionReplies: 5Last Post: 15th Sep 2012, 10:54 -
has anyone tried FORMAT FACTORY
By hilario in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2012, 16:42 -
Format Factory problem
By Stef2010 in forum Video ConversionReplies: 6Last Post: 29th May 2012, 16:31 -
Format Factory Question
By dexterdoo in forum Video ConversionReplies: 2Last Post: 2nd Aug 2011, 15:43 -
Little Problem during encode in Format Factory
By Stef2010 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 11:43
