  1. Hello.
    I have a mkv video containing 2 audio streams (ac3) for two languages.
    I tried all possible options to re-save it using mkvmerge with setting default flags and forced flags, but despite all my efforts only 1 audio stream is displayed when playing the file (Media Player Classic using)
    Can anyone help me how to add a switch to be able to change audio when playing the file?
    Thank you.
    So the source mkv doesn't work either?
    Maybe try extract both audio streams with mkvextractgui2. Add them back in mkvmergegui, disable header compression(file->settings and disable header compression by default) and make a new mkv.
    And use a newer mpc like mpchc.
  3. Thanks.
    I did that already. It didn't work. Same result.
    And you are correct, I use latest 9.3.6 version of Home Cinema.
    Any other suggestions?
  4. Any other ideas? I still can only see one option of Audio. The second stream is hidden
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    who says both audio streams are ok? did you make the mkv yourself? if not just delete it and move on, if it doesn't have the audio you need.
  6. I can extract and merge them individually resulting in 2 video files with one language each. But I can't play switch them one a single video file.
    My Samsung TV allows switching audio using remote control. But the option is hidden on a PC using latest Media Player Home Cinema
