Im new to using CCE 2.62 for encoding but if anyone can give me the lowdown on some quick setups I would appreciate it.
Im encoding AVI files to MPEG for internet downloadable delivery I want to be able to compress these files and maintain great to acceptable picture quality but at the same time want to save on bandwidth costs. Any suggestions on settings? Ive got an idea of where I want to start with the specs but need additional input and comment.
Thank you
Angel
The main power of CCE is the multipass encoding. It is fast and deals with low bitrates very well...if you are looking at sqeezing even more bitrate, look into using AVISynth of TMEPGEnc to do IVTC on the video (if your source is film), then you will gain %20 on bandwidth....
TMPGEnc has multipass encoding as well. So do many other encoders.The main power of CCE is the multipass encoding.
The main advantage of CCE is that it is 4 times faster than TMPGEnc.
The other main advantage is that the video encodied by CCE will be much higher quality, for high motion scenes, than that encoded by TMPGEnc. In my tests, which involved fairly short high motion scenes, the CCE MPEG stream encoded at 4Mbps was better than a TMPGEnc stream at 8Mbps.
Best CCE settings for 16x9 progressive video?
By mlong30 in forum Video ConversionReplies: 0Last Post: 18th Apr 2011, 09:22 -
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 17:17 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 18:30 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 05:20 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 12:56
