Please help me in saving/grabing frames from m2tsi movie file.
input : m2ts video file
out put : ALL frames saved as bmp files.
I used following script, and could see m2tsi movie on the screen, but all saved bmp files are corrupted. My similar/simple code worked OK with avi video file. What is wrong with my script ?
What I need is ALL frames of m2tsi video file converted in bmp files. (For test purpose, I have trimmed frames.) Without yadif.dll, my bmp files are corrupted as well.
Thanks in advance for your help.
DirectShowSource("C:\ux7.m2ts")
load_stdcall_plugin("C:\AviSynth\yadif17\yadif.dll")
yadif(mode=1)
Trim (0, 5)
ImageWriter(file = "C:\im\Remo%03d.bmp")
At my other post, thanks for poisondeathray, poisondeathray suggested to use following. Now bmp file is OK, but image quality is bad. 1 or 2 pixels seem shifted away etc. Any cure to fix the problem? Thanks for all.
DirectShowSource("video.m2ts")
ConvertToRGB(matrix="rec709")
and manono
you should reference where you detailed the problem and solution
https://forum.videohelp.com/threads/350045-%5BQ%5D-video-frame-grabbing-software
In your script above, you are single rate deinterlacing (half the fields are thrown away)
If you wanted to use yadif with double rate deinteralcing
Yadif(mode=1, order=1)
You need to specify order =1 for top field first (all HD content is usually top field first)
Another option is to use slower, higher quality deinterlacers like QTGMC
ffmpegsource2 error in Avisynth
By fidogenial in forum Newbie / General discussionsReplies: 23Last Post: 16th Jun 2016, 19:58 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 02:44 -
AVISynth script error
By rvnwlf in forum Blu-ray RippingReplies: 1Last Post: 24th Aug 2010, 20:52 -
By rvnwlf in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 14:33 -
meGUI - AVISynth Error!
By th3obr0 in forum Video ConversionReplies: 2Last Post: 27th Jan 2009, 22:20
