    Oct 2012
    Valencia city, Spain
    Hello,
    I need command-line-interface software to easy and massively remove tags and metadata from video type files:
    AVI, ASF ,FLV, MKV, MPG, MPEG, MP4, M2TS, TS, WMV
    PS: well, i use the program "mp4tags.exe" for mp4 tag vids so i don't need more soft for mp4 at the moment.
    I've searched so long too months on Google but i only found "abc AVI TAG editor" but it's a graphical app so...
    EDIT: i've found mkvpropedit.exe for metadata and tags on mkv files... one less!
    please, some help?
    Thankyou from Spain (not latin lol)!
    Maybe try remux with ffmpeg
    ffmpeg -i input.avi -c copy -map_metadata -1 output.avi
    Video and audio are copied.
    Oct 2012
    thankyou is very usefull
    i tested ffmpeg with avi and mp4 files, done it right
    but do you know if i can use it with the other formats that i need in "copy" mode? (i can't test it)
    PS: sorry for my english
    Yes, mkv, mpg, ts should also work. Maybe not if you have several audio,video, subtitle streams.
    Oct 2012
    Thanks again, and please... a little question (i don't found info about it)
    ¿what happens if I use the overwrite parameter "-y", for example like this way:
    ffmpeg -y -i "file.mkv" -c copy -map_metadata -1 "file.mkv"
    I mean... what happens if ffmpeg crash or something (because subtitles or a crash into pc or anything)?
    ffmpeg copy process is "on the fly" inside the same file? or fisrt ffmpeg make a temp file and after that overwrite the temp file with the original fille?
    so... if i use "-y" but the copy process don't finish by a crash or something then i get a half-cutted and corrupted overwrited file or I don't need to worry about that?
    thankyou for all the info gived to me!
    PS:
    I made an automated processing of all my vids in a Batch script,
    the script search for some values into metadata of files, if found any of them then convert the file overwriting it...
    but i don't want to loose a vid file cause a crash or something of ffmpeg so i need to confirm this question please...
    EDIT:
    Ok I've monitorized the files created with the app "moo0 file monitor" and ffmpeg copy process is too dangerous, don't make any temp file, it extracts and add the datas on the fly inside the same file,
    this means if a execute the copy process in a 800 mb mp4 file and then I kill the ffmpeg process at the start of the process then i get a corrupted 619 KB file...
    PS: tested!
    Don't overwrite important files with ffmpeg, this app don't have any protection measure like writting first into a temp file, trust me!
    bye
