Ive only done this with AVI files in the past and that was clear back in 2005 so I havent been doing this too much.
I have a bunch of MKV files I encoded that look much better than the original DVD footage after using AVISynth to properly filter it. Their video format was MP4 with H.264 codec before I muxed them and their 640x480 resolution.
I want to make a DVD that can play them back on my DVD player, hopefully I can get them to be anamorphic as well. I also wish to be able to make my own DVD menu to go with them but I don't know any good software for doing what it is I'm looking to do. Any good software's for doing this out there?
If I can keep the soft subtitles and multiple audio tracks that would be a plus but I only mostly care about making a menu of my own and getting the English version with or without subtitles onto a DVD that will play back in standard DVD player or PS2.
Results 1 to 10 of 10
Use avstodvd. You can do subtitles and multi audio tracks with it. And you can do widescreen (assuming of course they were originally widescreen, it gets a little trickier if it was a letterboxed widescreen - that is widescreen in a 4:3 matte).
Just an fyi if you or your target audience has either a xbox 360 or ps3 there is a chance you can play the original mp4 as is without alteration - though it will need to be mp4 not mkv as neither will read mkv (unmodded that is). But its not a gimme as they are particular about the type of h264 they will read. If they were downloaded off youtube its a good bet they'll play them.
But since you are looking to make a regular old dvd then avstodvd is where you should look for your conversion needs. And burn with imgburn please
(freeware also - both programs are)
Edit just so you know sd dvd is 720x576/480 or lower so since you are working with 640x480 material you won't have to redo a lot. I don't know the particulars for resizing back to 720x480 for dvds but avstodvd should automate the process for you (480 assuming you are in ntsc land)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Convert to a mpg or video/audio streams with avstodvd (using the hcenc enoder).
Author the mpg/streams with for example dvd styler, dvd lab pro,etc. -
That software doesnt look like it lets me create DVD menus like I said I was wanting to be able to do. It just seems to be a converter to convert the video to a format for DVD burning.
I want to be able to make menu's and burn a fully customized DVD. I used to use a software called "Ahead NeroVision Express" but that was clear back in like 2005-2006 that I last used that. I dont think it knows what MKV is. I can only get it to work for AVI.
But anyways that software is an example of what im looking for. I just want to be able to do MKV instead of AVI. -
nvm I found this and it looks like it will do what I was asking to do.
http://tmpgenc.pegasys-inc.com/en/product/taw5.html -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
how to play mkv file on dvd player with usb
By ashe09 in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 01:46 -
Burning some WMV and MKV files to play on a DVD Player
By marnisper in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2011, 09:24 -
MKV to AVI to play in standalone DVD player
By AzzKickr in forum Video ConversionReplies: 8Last Post: 9th Sep 2011, 14:53 -
is there a DVD player that can play .mkv files?
By gd6noob in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Dec 2009, 21:35
