anyone know how to transfer files between 2 pc's from firewire to firewire in Win98?
I'm not exactly sure, someone here gave me a program to do it, but i decided that for all the time and trouble, a Dazzle DV Bridge is chepaer
IF YOU UPGRADE BOTH MACHINES TO WIN XP, YOU CAN NETWORK VIA FIREWIRE EFFORTLESSLY. (NICE EASY WIZARD HOLDS YOUR HAND THROUGH THE WHOLE PROCESS) i USE IT, AND ITS VERY VERY FAST!
If you don't want to upgrade your OS the only way I know of is to use Unibrain's FireNet software. Download it from their website (www.unibrain.com). It's a trial - 30 min per windows session before it expires until the next reboot. Easy installation, good performance (unless you want to use it with Windows ME which for some reason is very slow).
does anybody know how to transfer data between two computer through USB one with XP pro and the other one with ME. I just dont have firewire on one of the computers. What program do I need or all I have to do is just connect the two computers and use the data transfer wizard?
Thankx a lot -
For this you would need a special USB cable. Check www.lpt.com for more details.
I know www.belkin.com makes a cable usb to usb. I don't think you need software you would jusst have to do it like you would with a Network cable...
Want to transfer video but no Firewire port on laptop!!! Aagh! Please help!
By colinb1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Apr 2011, 13:08 -
Questions about DV transfer and connectivity of Firewire/1394
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 14:46 -
Firewire transfer from Sony HDR-HC1E
By Richard_G in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 26th Apr 2008, 23:21 -
Bland picture after firewire transfer?
By Jazzy78910 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 31st Dec 2007, 07:10 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 12:29
