I'm looking for a subtitle tool (for syncing external subs /w film mainly) that is easy to learn and intuitive.
I do these things so seldom I forget complex instructions between times. Any suggestions?
Thank you.
	I still prefer to work with good old: https://www.videohelp.com/tools/Subtitle-Workshop
 with old version 2.51, which has good help file included and is easy to work with.
 If you would be looking for more advanced freeware then: https://www.videohelp.com/tools/Subtitle-Edit
	Thank you Jeremiah58, that was good advice. Yes, sometimes an older version can be better than subsequent ones.
 Perhaps Subtitle-Workshop was optimal and pretty darn good by v. 2.51? Then what does a developer do?
 Thx also for the freeware link
  Easy tool to change audio fpsBy davidbowie in forum AudioReplies: 20Last Post: 17th Jul 2014, 05:23
  Intuitive avisynth editingBy Mephesto in forum EditingReplies: 5Last Post: 25th Feb 2012, 10:31
  Seeking for some easy tool to convert camera video to x264By junglemike in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2009, 07:03
  Any easy tool to make a DVD photos slideshow with the background?By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 15:34
  Looking for easy tool to get length of a DVDBy lcluster in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2008, 20:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
