friends
sorry i dont know where to put this question so i decided to put it here,
well my problem is that i am using a yamaha A/V Receiver which has only 2 optical input whereas i have 4 devices which i want to connect to A/V receiver by optical cable, on amazon i found Toslink device in which i can put 3 optical cable in input and one output to my receiver, but i dont know about this brand whether its good or bad, if someone know any good and best brand please let me know so that i can solve my problem.
Why don't you post a link?
I was in a similar situation several months ago. (And once again, thanks yoda for suggesting the toslink switch).
I didn't see much difference at the low end for these switches on Amazon. (Around $10 bucks or so). In fact, I suspect that all the offerings in that range are made in the same factory, they look so remarkably similar. Some of the variants seemed to have nothing to distinguish them, one from the other, more than how many toslink cables are included.
So I got one with several cables, and it's been fine. I wouldn't worry about some of the bad reviews. Two reasons: First, people who will write a damn fool review are never lacking. Second, this is a dead-simple, and very cheaply made device. If one doesn't work, exchange it for another.
Good luck.Pull! Bang! Darn! -
Yeah, the same factory made the one in the link, and the one I have. Apart from the position of the output being shifted from opposite the #2 input, they're identical. A minor change. Same basic profile, same color scheme.
All it has to do is lock accurately into position.Pull! Bang! Darn! -
Another solution is to use two toslink y adaptors. They will work as long as the input devices don't send an optical signal when they are off.
If you have one divice that always outputs a signal (Tivo, cable box, sattalite box) then piggy back two y adaptors for 3 inputs for the other divices.
If you have two divices that always outputs a signal then get the switch.
HDMI out vs. Optical out
By toneystone in forum AudioReplies: 37Last Post: 18th Sep 2013, 12:41 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
Optical device stops working
By Crazewolf in forum DVD RippingReplies: 4Last Post: 10th Jun 2009, 06:20 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 11:53
