I have the video already converted to quicktime and the audio to aiff format. On some movies I can simply import the audio and add to the quicktime movie in Quicktime Pro; however, on some movies the audio is not in sync. So I use Final Cut Pro 2 to change the audio speed. The problem I have is that I have to export it to another file and use Premire to try and sync them because Final Cut Pro 2 says it can't handle my frame rate. It says my frame rate is 23.976 even when the frame rate is 24fps. No matter what it won't open the video. I have tired numerous frame rates with the same results. This is a very slow process and I'm getting tired of it. Any suggestions not involving me converting the quicktime file a second time?
-TGPO
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
