I have a creative 128PCI soundcard.
I unchecked the "check videosignal while recording" in the extended settings.
It helped and I now get about 2 dropped frames with 44KHz and none with 22KHz.
I don't get any drops when I don't record audio !
It also seem that I get more dropped frames when recording from a tape than from the video-tuner ?
If I rewind the tape while recording it goes bananas.
If the source of my trouble is my soundcard what is the best card to get ?(I can't find any ensoniq card)
I have posted another message under DC10+ frames lost covering this same issue. My machine is a little higher spec'd and I lose 2 frames per minute, higher with higher resolutions.
The common factors appear to be the CUSL2-C and even though my sound card is the SB Live, it is probably not that much different.
I found that if I use my ASUS V7700 GTS Deluxe for capture I do not lose any frames at all which seems to indicate somnething with the DC10+ or the combination with the sound card.
I am still searching for a solution. Hopefully someone has come up with one.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
