Hi,
I opened the file that I have attach below in DVD Remake and I saw that the PGC is compose of 10 identical cells.
So I was wondering if it is possible to merge the cells together and/or to edit the cell duration.
If it's possible, how to do it and with what program?
Any suggestion would be appreciated.
Thanks in advance![]()
As I can see, these are still cells shown in the very end of the movie. You can't join cells in this program, but you can leave just one of them (delete the rest) and set any wanted still time for displaying it (double-click on that cell in Programs). You can also edit the PGC's post-command to go to some menu (there's Exit command currently).
Thanks for your reply.
I try what was suggested using DVD Remake, but changing the cell time doesn't seems to work :S :
- I deleted all the extra cells, leaving just one,
- I edited the cell still time to 60 seconds.
Unfortunatly, when I play the video, it last 0.15 sec.
What am I doing wrong?
P.S. I don't know if it has something to do with it, but in DVD Remake, on Button option, you see the option Duration and it is set to .15 second, but it doesn't allow you to edit the duration.
Re-Organize PGC on dvd. PGC Edit?
By DStep in forum DVD RippingReplies: 9Last Post: 17th Sep 2012, 03:43 -
Button to link to PGC in another Video Title Set + disable audio in cell
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2010, 03:04 -
Options for PGC indexing?
By Gew in forum DVD RippingReplies: 3Last Post: 22nd Feb 2009, 14:34 -
Pgc edit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 12th Jan 2009, 13:05 -
PGC edit
By kshavo in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2007, 18:47
