  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi there
    I was wondering if anyone knows how to make it so i can record with a USB webcam?
    Then save it to a common format such as AVI, MPG etc?
  2. Just about every video capture program can record from a webcam. VirtualDub, for example.
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    Ah yes ive found that on virtual dub thanks for that!
    How do i stop the output filesize from being so big?
    I recorded like 30 seconds and the size is 280 MB.
    what settings need changing?
  4. Video -> Compression
    Audio -> Compression
  5. Member SE14man's Avatar
    Jul 2005
    Queensland
    When i do this though it doesnt play the avi properly afterwards.....
    It plays the first frame and thats all and just plays for the 10 seconds i recorded for but with the picture frozen.
    What settings should be applied in XviD?
    Just wanted to now add when i play it back it plays in VERY VERY slow motion. Almost 1 frame per 5 seconds.
    Aah ok thats because i played it back in VLC but on WMP is fine
    So how would i make it so the output file plays well on VLC?
    Thank.
    Im wondering if Klite codec pack might be responsible for this?
    I should really stay away from that shouldn't I?
    Should i remove it and if so what should i have installed on here to get the best setup?
    What would you guys recommend?
  6. Capturing with slow codecs like Xvid isn't advisable. Use fast lossless codecs like Huffyuv than convert to Xvid later. Same with audio.
    Generally good capture advice: https://forum.videohelp.com/threads/104098-Why-does-your-system-drop-frames
