Is there any software that allows me to edit an MKV the same way I can edit an avi (lets say xvid) in vdub?
My requirements are:
1# Need video and audio
2# needs to be very, very easy (as in I can visuall see the video as I edit it and can 'cut' parts out)
3# ideally it wont re-encode (kind of the same way mkvmerge doesn't re-encode).
These edits do not need to be down to the frame. Even if its 1-2 seconds off its ok for this project.
Results 1 to 10 of 10
hmmm, interesting tool, but when I do a edit I do not have any video in MPC HC but video in VLC (which I do not use).
I also tried an FLV lossless video only edit. It did manage to load the file but when I tried to save it as HuffYUV codec it doesn't play in either of my MPC HC versions, in VLC or even with directShowSource. -
I thought you didn't want to re-encode ? Technically you lose quality with huffyuv because it's upsampled to yuy2, and when you re-encode again to your final format, you will lose quality again
video=>copy
audio=>copy
format=>mkv
This would be similar to editing in vdub with "direct stream copy" with no quality loss
I also tried an FLV lossless video only edit -
I do not want to re-encode the mkv. I was able to save it as an mkv with my edit. But I did not get any video (black screen) in MPC HC. Only audio. I did about 1m test on two seperate MKV files.
But now that I got that app installed I do want to re-encode an separate FLV into a lossless format, with or without audio. I got an FLV that wont open in vdub (with directshowsource), so im hoping avidemux can solve the issue (I just cant seem to encode it).
btw: No matter what file type I try (flv or mkv) the encoding screen (haff or mkv copy) stays at 0% till its done encoding. -
avidemux is 3.6 32 bit (not all that stable tho, ive had to kill it in the task managed 4 times now).
mkv:
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=10
Codec ID : V_MPEG4/ISO/AVC
as for the flv, not sure. But the mkv right now is more important. -
you mean 2.6? (not 3.6?) .
Some people are having problems with the newest 2.6 , try an older version. I've tested it on dozens of mkv and flv videos and it works fine . Or even go back to 2.5.x builds . They don't necessarily have to be installed, you can use a portable version
http://avidemux.razorbyte.com.au/
It just seems avidemux cannot encode it correctly.
If you are re-encoding the flv, you can open the flv in vdub with the ffinputdriver plugin for vdub , or with an avs script with ffms2 , or even use another utility like ffmpeg (or a GUI like winff, avanti) -
yeah 2.6, was a typo....
I tried 2.5, failed to load several flv's, once I got one working the encode seemed to have worked (was able to load it in VLC).
I also did a 'copy' on the mkv, so not sure what is happening. I can play the original fine, but the edit gives me no video.
Maybe ill look at all of this tomorrow. Been drinking tonight :P
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
MKV as source in VirtualDub?
By Xavier in forum Video ConversionReplies: 16Last Post: 16th Sep 2011, 23:04 -
Trouble with .mkv and VirtualDub using AVISynth
By Jonnycat in forum Video ConversionReplies: 3Last Post: 6th Apr 2010, 16:43 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
mkv editor like VirtualDub
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 19:42
