Hey guys,
I want to put a static background behind the guy in this video using HitFilm. Based on your experience, what problems am I going to run into? Is the lighting proper? How about colors?
It's just a short snippet of the full video - about 7 seconds.
http://youtu.be/aavNWGQwNbI
	uneven lighting - the key will more difficult
 looks like you're shooting interlaced - more difficult to get clean edges, and interlaced chroma issues, low chroma resolution
 ringing or "haloing" around the actor - make sure you turn camera sharpness way down, otherwise more difficult to get clean separation
	Even and bright are the way to make it work. You don't have anything properly lit in your scene.
  Chromakey kitsBy proud2b4family in forum Newbie / General discussionsReplies: 0Last Post: 31st Mar 2011, 19:38
  Where to find moonscape backdrop video for chromakey?By lboiv001 in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 07:04
  Help with HF200 (24p and 30p question) technical questionBy Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24
  Mod16 question and DAR question...By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18
  Age old question of VHS to DVD question...I still don't get it.By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
