Here are my steps:
- downloaded 1 hour of digital video (roughly 12 gig AVI file)
- used Virtual Dub to compress it into a roughly 3 gig AVI file using one of the good AVI codecs (Cinepak or Intel, can't remember which)
- used TMPG to convert to MPG2
It seems that TMPG has totally skewed the audio track. The first two minutes of the MPG2 are fine, but then there is 24 minutes of no audio. Then at minute 26, the audio for minute 3 starts up. So my audio is running 24 minutes behind the video.
I'm using TMPGEnc 2.5
Thanks,
Jeff
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 01:15 -
Q: Adaptec AVC-2310 MPG2 Capture - Need: Shrink/Fit to DVD, Redo Audio
By jpneok in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2007, 20:06
