Hi,
When i convert a 720 or 1080p movie, with DTS 1510 Kbps audio track, to DVD using AvstoDVD, newest version, i get a horrible sound output. its just a long high noise, no speaking, just loud noise.
I have tried to check and uncheck "Keep DVD Comliant Audio", and used "FFMpeg+Aften" and "FFMpeg" with a final of DTS, and another with AC-3 448 Kbps, same result.
I use FFDShow, and i've done a new and clean install of both AvstoDVD and its features and ekstra programs, and FFDShow, same results..
Anyone knows what i am doing wrong?
Thanks in advance.
Results 1 to 15 of 15
Sure, here they are, some of them:
http://www.mediafire.com/?bnpkdsz1otnb8tt
Thanks. -
It's messing up the audio channels.
I make my own AVS scripts to make conversions, and often have to experiment with different downmix functions.
I use one of those from here: http://forum.doom9.org/showthread.php?p=1243880#post1243880
Even if you're not downmixing to stereo, you need to remap the channels.
I use this to hear each channel separately (uncomment one line at a time and test) to work out which mapping to use:
Code:#GetChannel(1) # #GetChannel(2) # #GetChannel(3) # #GetChannel(4) # #GetChannel(5) # #GetChannel(6) #
I don't use AvstoDVD, so I don't know how it's doing this.
But I asume it's using Avisynth,and I hope there's a way to see and modify the script.
I do know that when I do an audio conversion using Avisynth, that sometimes the order of channels isn't as expected, (at least as Avisynth interprets it) and then I hear. e.g., subwoofer channel instead of the front or left/right, and it often does sound as you describe.
See http://avisynth.org/mediawiki/GetChannel -
maybe you can demux the audio from the original file and remux it with the resulting video
I tried it on a DVD and on my Dune HD Smart D1, no audio, just i very high scattering noise..
Maybe thats an option, ekstract it from the MKV, convert i to AC-3, and mux with muxman.maybe you can demux the audio from the original file and remux it with the resulting video
Because i already demux the result, adding subs, and mux/author agian..
So it wouldn't be that hard to add an audio track.. -
Yes i have, ill upload the whole file to dropbox, and i vil post the link when done
AVStoDVD audio out of sync on converted mkv
By whammoed in forum DVD RippingReplies: 23Last Post: 11th Jul 2014, 10:00 -
No Audio when converting MKV to DVD using AVStoDVD?
By |StarscreaM| in forum Video ConversionReplies: 14Last Post: 8th Jan 2013, 23:57 -
No subtiltes no sound - Converting Avi to VOB using AVStoDVD - no success
By Ze Tomes in forum Video ConversionReplies: 7Last Post: 23rd May 2011, 23:23 -
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 2nd Apr 2011, 23:27 -
AVStoDVD or MultiAVCHD? for .mkv 720p on DVD9
By vandaLo in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2010, 19:12
