Hi
A friend took some video for me and gave me the SD card - I'm able to see it in several programs but it's always playing in slow motion though the sound is normal. How can I get it to play normal speed? Or covert it to normal speed? Thanks!
				Results 1 to 19 of 19
	Using a mac and it's new and fast. Never had probs with any other video format. Had no idea there were different kids of MTS. Will download media info and find out. Thank you!
	Hi Poisondeathray... here is the info. Haven't a clue what it means!
 BDAV: 9.74 MiB, 6s 681ms
 1 Video stream: AVC
 1 Audio stream: AC-3
 1 Text stream: PGS
 Maximum Overall bit rate: 18.0 Mbps
 Video 11.5Mbps 1920*1080 (16:9) at 25.000 fps, AVC
 (high@L4.0) (CABAC / 4Ref Frames)
	Problem is I want to edit it and have to get it to play in an editing program or somehow convert so I can do that. But I'll try one of these programs you suggested to see if at least I can get it to play properly. Will let you know. Really appreciate you help.
	You can edit it with premiere pro , or fcpx . If your computer is fast enough it will play properly
 Unless there is something wrong with the clip - did the person who sent it to you check it ?
	Yes he did. I'm wondering if it's a UK camera and I'm trying to edit in USA would that make a difference with how it captured to the SD card?
	I want to use iSkysoft Video to edit. I can't afford the other programs and don't like how they work. That's why I need to get it working as maybe another format properly
	No, the transfer will be identical the original file. It's a direct digital transfer.Yes he did. I'm wondering if it's a UK camera and I'm trying to edit in USA would that make a difference with how it captured to the SD card?
 But notice it's 25fps . That's not a standard framerate for a NTSC or 60Hz country like USA . It may cause some issues depending on what your final format goal is (e.g. DVD, blu-ray, web ....) . You need to provide more information
 I don't know anything about iSkySoft . Maybe it's just junk software ? If your computer is fast enough , it should be able to edit it . But note editing requires a lot more processing power than just playing it in a media player . If you can't even play it in a media player properly, you have big problems and probably need a hardware upgrade. HD content (especially AVC) requires a lot more processing power than SD content
	What is your final format goal ?
 If your current software doesn't work properly try something like imovie, or the free version of imovie hd .
 Is this it ? It says it supports AVCHD
 http://www.iskysoft.com/video-editor-mac.html
	imovie doesn't support AVI, and has problems with some types of MP4 . I think imovie HD will convert the AVCHD to Apple Intermediate Codec
 you can use clipwrap to rewrap into mov (there is a free trial)
 or you can use ffmpeg to rewrap into mov as well (but you need to open up terminal - command line usage)
	you are taking to someone who is relatively new to using a mac and doing this stuff. LOL! I hate imovie which is why i bought iskysoft. So you are saying you think I can convert successfully into .mov and then use imovie worst case. Is there anyway I can get iskysoft to play it and save it? I rather edit in this as it's the only editing program I've been able to figure out.
	I hate imovie too and I don't use macs very much. When I had to edit things on a Mac I used either Premiere or FCPX . They can edit AVCHD natively. I have no idea what iskysoft can or cannot do; but it says on that webpage they support AVCHD
 I know that anything wrapped in MOV will work better on any mac program, probably iskysoft too (re-wrapping doesn't alter the quality , it's like taking the audio & video out of 1 "box" and putting it into another "box")
 If say, your goal was something SD like DVD, then you might convert it to smaller resolution and lower quality and it would be easier to edit
	Maybe I need to write iSkysoft. As if it supports AVCHD then you feel it should work? Maybe I have to change a setting or output?
	Did you check the webpage linked above, is it the same product? It claims to support AVCHD - so I would expect it to work
 I'm not familiar with it, so maybe start another specific thread (with the product in the title), or see if they have a help forum
 And since the file plays ok in VLC, that likely rules out problems with the footage itself
  I have MTS files and want to burn them onto a DVD a normal player will readBy JaneHarris in forum Newbie / General discussionsReplies: 5Last Post: 24th Sep 2012, 14:10
  MTS to AVI on slow computerBy Mort126 in forum Video ConversionReplies: 1Last Post: 29th Jun 2010, 16:01
  best speed to shoot to get slight slow-motion effect in music video?By Cumie Music in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2010, 00:58
  Need MTS Player with Slow MotionBy mightyjak in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 09:47
  How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 13:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
