o.k. now that i have vented, i think i found the right forum.
i am a computer newbie running a mac os 10 with a build in cd burner.
i am using i-movie and importing .jpg pics to use as a family photo album
which can be used on my dvd player.
my problem is, the movie comes out as a .mov file and when i burned it
on to disc, and put it in my dvd player, it said, "disk error" and spit out
the disk...my dvd player is both cd/rw and vcd compatible and if anyone
can help, i would be most grateful...thanks in advance.
Bill :( :roll: :oops:
I dunno much either but seing no one in here reply i decided to give this a shot, i think you have to convert it to mpeg1 or mpeg2 first then burn it on a disc using vcd burning program (ex. - Nero, Nti, etc...), and if u want to know u should look around in this site.
The best program to burn vcds on a Mac is toast. Once you have the .mov file all you have to do is select Video CD and drag the .mov file to it. Then burn and enjoy.
-TGPO -
THANKS SO MUCH TO GOKONG AND ESP. TO TGPO! I THOUGHT I HAD TO CONVERT ALL THE PICS AND ALL THAT OTHER B.S.!!!
SO, THE .MOV FILE CAN BE CONVERTED BY USING TOAST...TOO COOL!!!
AGAIN, THANKS SO MUCH!!! BY THE WAY, I SEEM TO HAVE SEEN A DEMO
SOMEWHERE OF TOAST 5...DOES ANYONE KNOW WHERE TO GET IT?
I'M A LITTLE LEARY...IT WAS A 30 DAY TRIAL I BELIEVE..IF IT WORKS,
HEY, I'LL BUY IT!!!
LIVING ON DISABILITY IS A PAIN IN THE ASS!!!!
BILL -
Bill,
I don't know for sure but you can try searching off of www.google.com or www.download.com
Anyone know anything about this censorship bill?
By ranchhand in forum Latest Video NewsReplies: 8Last Post: 19th Nov 2011, 09:57 -
Help with Kill Bill 1 & 2 Blu-Ray subs
By jntaylor63 in forum Blu-ray RippingReplies: 0Last Post: 31st Jul 2010, 11:47 -
How much is your monthly cell phone bill?
By 3Simon7 in forum Off topicReplies: 15Last Post: 24th Dec 2009, 10:38 -
French net piracy bill signed off
By TBoneit in forum Off topicReplies: 2Last Post: 11th Jun 2009, 15:53 -
When a Mac fanboy meets Bill Gates...
By joytimeday in forum Off topicReplies: 2Last Post: 22nd Feb 2009, 23:38
