My notebook's resolution is 1200 by 800 pixels , it can play 1080p videos! Does the player automatically scale down the 1080p to 720p? In doing so, it must reducing the quality/bitrate of the video. In other words, does it act as a converter implicitly because that's the job of a video converter , isn't it?
Which player is best developed for this scenario in windows?
	The player can play at that resolution of 1080p but ur screen resolution will not allow to see u at that resolution ur basic quality of ur screen is 720p. So next time check the resolution of ur laptop before buying one. Perhaps get ready for 4k screen resolution.
	The graphics chip inside your notebook is re-scaling to it's native resolution of 1200*800
	If it's keeping the aspect ratio it's scaling 1920x1080 to 1200x675 and adding letterbox bars to bring the frame up to 1200x800.
	You wont see a loss of quality on a smaller lcd screen with the picture being scaled done. I think,therefore i am a hamster.
	You may or may not notice artifacts from scaling. It depends on the video and the scaling algorithm used. For example, the thin lines in the attached test pattern video will show some artifacts when scaled. But with most real world video it won't be as noticeable.
  Resolution, pixels, bitrate and bytes transferred over networkBy loveaks002@gmail.com in forum Video Streaming DownloadingReplies: 14Last Post: 5th Dec 2011, 13:03
  How Can I Convert DVD to HD 1080p resolution as easy as HD 720pBy hd hackerz in forum DVD RippingReplies: 5Last Post: 11th Jan 2011, 04:54
  What's up with 1080p encodes missing pixels?By Quasit in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2010, 15:25
  Taking pictures from Logitech Webcam in 1600*1200 resolution using C#By rostamiani in forum ProgrammingReplies: 0Last Post: 28th Jan 2010, 05:08
  Plasma Resolution...1080p FulHD but 1024x768 res...???By snadge in forum DVB / IPTVReplies: 40Last Post: 8th Mar 2008, 19:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
