Results 1 to 9 of 9
  1. Member assburger's Avatar
    Oct 2012
    Montreal, Quebec
    What other good programs are there for merging .AVI files, other than the VirtualDub[Mod]?
    VirtualDub is too strict and doesn't allow to join a lot of types of avi files.
  2. Member assburger's Avatar
    Oct 2012
    Montreal, Quebec
    Hmm, will give it a try, thanks!
    God is a superstition; religion is poison.
  3. Member assburger's Avatar
    Oct 2012
    Montreal, Quebec
    I'm using WinFF to join avis and I now have to select a Preset out of a whole bunch of presets.
    Which preset should I choose if I want it to be like in VirtualDub when you pick "Direct Stream Copy" - the resulting file size and video quality remains the same.
  4. Member bat999's Avatar
    Feb 2008
    This program is not suitable for joining avi files.
  5. Member assburger's Avatar
    Oct 2012
    Montreal, Quebec
    What? Why?
  6. Member assburger's Avatar
    Oct 2012
    Montreal, Quebec
    So yeah, I ended up using avidemux and it was superfast (like under 10 seconds fast! to join a gig of avis) and exactly what I needed!
    So no more impossible joinings like it was with the VirtualDub!
    Aug 2002
    South Florida
    If you have a video editor you can simply use that, i.e., VideoStudio, Vegas, etc.
