I'm looking for an opensource or free programs that can join wmv clips without the re encode which results to long wait. The clips that I have are split and looking for a way to join them easily and fast. Any recommendation?
Results 1 to 16 of 16
Any idea why the program gave me an error saying "the application has failed to start because the application configuration is incorrect."? The readme file said the application was ready to use.
There are some pre-requisites, see the developer's webpage
http://www.radioactivepages.com/asfbin.aspx
NOTE: AsfbinWin requires MFC 9.0 libraries to run. If required, download and install them from the following location:
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/downloads/en/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-38...displaylang=en -
Disregard. Checked the website and had to download the C++ distributed package or something.
It's the same thing : .wmv is an .asf stream
You can safely rename the extension from .asf to .wmv , or add .asf as a filetype registered to kmplayer -
*Working asf file*
Format : Windows Media
File size : 84.9 MiB
Duration : 11mn 25s
Overall bit rate mode : Constant
Overall bit rate : 1 038 Kbps
Maximum Overall bit rate : 1 044 Kbps
Encoded date : UTC 2007-05-22 06:18:31.687
Video
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9
Duration : 11mn 25s
Bit rate mode : Constant
Bit rate : 1 000 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.109
Stream size : 81.8 MiB (96%)
Language : English (US)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9 - 32 kbps, 22 kHz, stereo (A/V) 1-pass CBR
Duration : 11mn 25s
Bit rate : 32.0 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Bit depth : 16 bits
Stream size : 2.62 MiB (3%)
*Non-working asf file(joined 2 files using asfbin)*
File size : 172 MiB
Duration : 23mn 14s
Overall bit rate : 1 037 Kbps
Encoded date : UTC 2007-05-22 04:42:07.875
Video
Format : VC-1
Format profile : Main
Codec ID : WMV3
Duration : 23mn 14s
Width : 640 pixels
Height : 480 pixels
Bit depth : 8 bits
Stream size : 166 MiB (96%)
Audio
Format : WMA
Codec ID : 161
Duration : 23mn 14s
Bit depth : 16 bits
Stream size : 5.33 MiB (3%)
Pixel aspect ratio : 1.000 -
Clips 1 & 2 have the same mediainfo. That's ok bud. I appreciate your help on this. I'll try to mess around with the config more because I do have 4 players(KMPlayer, VLC, MPC and WMP). Can't remember though if downloaded a special codec but I had a few video issues before that involves messing with preferences. If all else fails, I can live with VLC or maybe reformat my pc which I will be doing anyway soon. Thanks again.
free avi joiner error
By natty in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 05:29 -
Best merger or joiner without re-encoding software?
By diodox in forum EditingReplies: 2Last Post: 18th Aug 2010, 07:18 -
Need Command Line video joiner (preferably free tools)
By Nintynuts in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 18:36 -
Free or paid - best video converter and Joiner?
By tigerb in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 18:57 -
XM-Sirius Merger
By Epicurus8a in forum Off topicReplies: 13Last Post: 17th Jun 2008, 07:19
