    Jan 2004
    Iowa, USA
    I have a new Verbatim 8 GB USB flash drive that Windows shows has 7.98 GB free space. When I try to copy a 4.2 GB Acronis "True Image" back-up file (xxx.TIB), I get an error message that says "The disk in the destination drive is full", and "There is not enough free disk space". I did a FAT32 format several times, but no difference.
    However, I can copy a 4.2 GB DVD folder/files to the flash drive, or any other non-.TIB file, with no problem. Any idea what might be going on here?
  2. FAT32 has a 4 GB file size limit. No single file can exceed 4 GB.
    Aug 2008
    Australia
    Format in ntfs
    Jan 2004
    Iowa, USA
    Oh yeah, I forgot about that! Thanks.
    isapc
    : I'm running XP w/SP3, and the only choices I had were FAT32 and exFAT (whatever that is). How can I format a flash drive in NTFS?
  5. DECEASED
    Jun 2009
    Heaven
    ^ Try the command-line interface
  6. Banned
    Freedonia
    Ask and you shall receive:
    http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
    Seriously, this came up in mere seconds on a Google search, so next time consider actually trying that instead of asking to be spoon fed.
    Jan 2004
    Iowa, USA
    jman98: thanks for the helpful link -- worked perfectly. I thought all flash drives were formatted as FAT32 because they "had to be" due to some technology limitation (that I thought I read years ago -- I'm no computer expert), and didn't know they could be reformatted to NTFS.
