I am currently encoding a 1080p movie... source is 34 Mbps
Re-encoding parameters, 1920x1080
CRF 16
Ref frames=5 B frames=6
8x8 transform, CABAC, weighted p frames
B pyramid, b frames optimal, Trellis always
uneven multi hexagon, motion est range 64, Subme=10
Partitions=all, deblocking = 6, deblocking = 6
U notice my deblocking is 6:6, I chose that because I was aware it improved compression significantly
but i keep reading and people say it adds blur to the video
I do not have the deblocking FILTER enabled, just the advanced h264 settings
Yes it will be more "blurry" and the filesize will be smaller than if you used the same settings with lower or negative alpha/beta deblock values
If your goal was improving "compressibility" , you would be better off using dedicated noise and grain processing filters . It will yield better results and more control -
Look at small details in dark areas. Those will suffer the most. And use a program where you can flip back and forth between the two videos while zoomed in.
Re:- Deblocking and artifacts removing - help/suggestion required
By ABBrittain in forum Video ConversionReplies: 1Last Post: 29th Jun 2011, 13:06 -
dv cassette deblocking
By noiz in forum RestorationReplies: 7Last Post: 16th May 2011, 18:13 -
Aggressive deblocking? Or what can I do with this video?
By Asterra in forum Video ConversionReplies: 5Last Post: 13th May 2011, 09:12 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17 -
deblocking a video
By themaster1 in forum Video ConversionReplies: 3Last Post: 26th Feb 2008, 10:44
