Someone I know did a 720p rip of Dexter Season 1 from his blurays
It is oddly, the highest detail I've ever seen in a movie/show, and its only 720p
Here's some screenshots from Season 1 Episode 1 (no spoilers)
00014 http://picturepush.com/showformat.php?format=img&image=10722611
00010 http://picturepush.com/showformat.php?format=img&image=10722688
00001 http://picturepush.com/showformat.php?format=img&image=10722649
00004 http://picturepush.com/showformat.php?format=img&image=10722675
00003 http://picturepush.com/showformat.php?format=img&image=10722663
Here's the MediaInfo for Season 1 Episode 1
Here's the encoding settings if anyone wants to review themCode:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 53mn 3s Bit rate : 5 258 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.238 Stream size : 1.91 GiB (87%) Writing library : x264 core 65 r1057 5f8a149 Language : English Default : Yes Forced : No
Code:Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5258 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
It's a good looking show! Keep in mind though, the coarse facial hair, the lack of makeup on the actor, and the close ups all enhance the perception of detail. Stylistically, they are going for a rough texture, where on another show the actor himself may have a smoother appearance via makeup and lighting, but not due to different encoding settings.
these encoding settings are not so good
5 258 Kbps bitrate is plenty high for 720p video - so the result encoding is fine -
Well I'm not saying the encoding settings are maximum efficiency
I'm just giving the mediainfo + encoding settings
the encoding settings aren't "optimal", but the bitrate is sufficient, so that makes up for it... I'm not sure exactly what I'm trying to say, but lol...
if the bitrate was too low and encoding settings too low, that's different -
Dexter series have always great PQ.
Even now (season 7) they have one of the best camera rigs ever used.
An awesome combination of Arri Alexa & Nikon D800.
If the footage is good , it is easier for us to make better encodings.
I agree that you could use lower bitrate. -
Height : 720 pixels
Right, you must have not seen many good encode. -
Very sharp. Really ugly color and blacks, though. Count me out.
Best settings for anime encoding?
By The Scenes in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2011, 19:28 -
Reading Encoding Settings
By dogar in forum Video ConversionReplies: 5Last Post: 8th Dec 2011, 07:30 -
Optimum x264 encoding settings
By zammil in forum Video ConversionReplies: 27Last Post: 18th Dec 2010, 01:32 -
Some questions, Re: 5.1 mixes, sound quality and encoding settings...
By takearushfan in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 04:13 -
Best quality settings for Xvid Encoding
By Shibblet in forum Video ConversionReplies: 1Last Post: 1st Sep 2008, 21:50
