Hello,
I uploaded a small sample of the audio with noise.
Download:
http://www.mediafire.com/file/441qbu72j3pd72b/VTS_01_1_Tc0_L2_2ch_48_256_DELAY_0ms.mp2
How to filter this noise?
There is a way to improve the quality of the audio?
What noise ? I can hear two or three audio sources but no 'noise'
I hear a lot of tape hiss once you crank up the volume.
Using Audacity, find a silent (except for the noise) section, and sample the noise. Then apply the noise filter to the clip.
Also, since the source had no high frequencies except for the noise, you can use a low pass filter. Set the cutoff around 4 KHz.Last edited by jagabo; 5th Oct 2012 at 09:22.
Best software to filter noise in audio?
By gil900 in forum RestorationReplies: 10Last Post: 8th Aug 2012, 19:02 -
Do I need a noise filter for Senn plug-on transmitter ?
By AAC in forum AudioReplies: 1Last Post: 15th Aug 2008, 12:55 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 11:18 -
How to use Convolution 3D filter in VDub? Is it the best for noise rem?
By Srivas in forum RestorationReplies: 8Last Post: 8th Dec 2007, 19:59 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 09:43
