I am having success with .avi files, but am wondering if that is the best way to go? Should they be mpeg instead? If so, which (2/3)? And what codec to use?
Thanks!
Results 1 to 15 of 15
For DVD-Video (I'm assuming that's what you want since you posted in the authoring DVD subforum) , you only have 1 choice: MPEG2
Yes, DVD-Video is what I meant.
So how come .avi files work with DV Video codec work? Ok, the name DV Video implies that it should, but just wondering..... -
They don't work directly. DV is a different type of compression. DV-AVI is re-encoded to MPEG2 video stream before authoring, either by your video editor or authoring program before making the DVD
If you meant a DVD data disc (not playable on a regular DVD player, only playable on a computer), then you can leave it as DV-AVI -
ED: no sense repeating the above info. But if you don't know what "DVD" is, try this: https://www.videohelp.com/dvd
It's going to depend on what programs and software you are using.
Some authoring programs only author and cannot encode. In that case you would feed them elementary streams (audio & video) from another encoder . Sometimes you have to do certain things to the audio to make it DVD compliant as well. e.g. Some DV camcorders record audio at 32000Hz, but that's not compliant for DVD . Other programs are "all in one" and do everything for you -
I am using DVD Architect. A look at the 'make dvd' process tells me it is going to be compressed/converted.
Thanks! -
No, you're not wrong.
I stayed away from this thread when I saw the OP's first post because I realized that he needed a LOT of hand holding and I lacked the interest to do it. No offense, but you are one of the guys with maybe too much patience here so this kind of thing sort of is up your alley.
jaccarrnio - I advise you to think VERY carefully if you are going to continue around here. Copping an attitude when people are trying to help you is a really bad idea if you want to continue to get help, although sanlyn has shown an interest in "lost causes" before and he might continue to help you no matter how big a douchebag you try to be. If you are such a genius then...
1) Why are you asking for help?
2) And why are you asking in a way that makes it seem that you don't know anything? It's not OUR fault that YOU can't describe your situation very well.
Again, think carefully before you reply. I've seen your kind before and I'm done here. But others may bail on you too if you post more snarky comments like the above. -
Dude - your post is unwarranted and you sir, are out of line. You have no business saying I had an attitude, regardless of who I was talking to. And don't YOU tell me to answer carefully. Who the hell are you? Outside of that one line above, I have been nothing but thankful and respectful, but of course you conveniently leave that out of your otherwise useless dribble. And the one line that was neither, was not uncalled for, due to the nature of what I responded to. And again, that is irregardless of who said it. See, it's not like people who are forum members for a long time get to do and say as they please. I came here for help, I got it, and again, I appreciate the time and effort. So again, thank you for the help. Now, if that does not please you, that's too bad. Now go take a hike.
Not worth an argument. O.P. didn't like my answer, I guess because the link didn't have a "Make DVD" button.
Hope all went well.Last edited by sanlyn; 23rd Mar 2014 at 11:39.
Which file format to use
By drtanz in forum Video ConversionReplies: 2Last Post: 16th Oct 2011, 15:46 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 17:52 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Best HD file format?
By M.AD in forum Media Center PC / MediaCentersReplies: 1Last Post: 22nd Nov 2008, 18:07
