Not sure this is really the place to ask this but I was just wondering if there is any way to tell or check if a 5.1 audio track is truly 5.1 or just an upmixed stereo track?
If ALL 5 channels are UNIQUE & DISCREET, it either is a true 5.1 or it's a professionally-done upmix that spent extra time in signal isolation (which is nearly the same thing as a true 5.1).
If you get crosstalk (signal common to multiple channels) & phase anomalies, it's very likely upmixed.
Scott -
If this is from an official source than you should look into all the official printed releases of the video. Each one will tell you what was officially on the disc.
However if this is from the internet and not directly sourced from a "professional" ie studio release than its going to be a lot harder to know for sure.
Follow cornucopia's post and you'll get a good idea.
For me I would think it would sound "fake". I don't know how else it would sound. Basically if you compare it to a similar type of movie you would get a better idea. In other words a comedy matched to a comedy and action to action. Preferably from the same era or same studio if possible.
The two main points of emphasis for me would be the center and sub channels. If either "feels" weak or hollow its probably a faked upmix. Though I guess it could be done poorly if its a low budget film or a rerelease of a "classic" movie with a virtual surround sound mix - but usually they advertise those - you know like an old western or something before surround sound came around.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The source(s) are live TV broadcasts. What's the best way to look at them, just load the decoded 5.1 in Audition and check the Waveforms?
That would be one way. Or looking at a lissajous scope, or doing phase-inversion differencing.
Help Identifying Source
By Charolastra in forum DVD RippingReplies: 8Last Post: 14th Apr 2012, 04:19 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 23:59 -
Hi-8 playback source
By Cingular in forum RestorationReplies: 14Last Post: 11th Nov 2009, 10:02 -
DV Source to Web
By osmethod in forum Video Streaming DownloadingReplies: 2Last Post: 14th Dec 2008, 15:13 -
Capturing 16:9 source in DV
By BertRito in forum Capturing and VCRReplies: 19Last Post: 18th May 2008, 22:50
