Page 6 of 6
FirstFirst ... 4 5 6
Results 151 to 171 of 171
  1. Une autre question ... J'ai confirmé que les fichiers M2TS créés Notepad++ Malwarebytes FileZilla par HDWriter sur le disque cible ont la même taille que les fichiers mts du dossier STREAM sur le support de l'appareil photo. Le transfert ne s'effectue donc évidemment pas au-delà du transcodage. jouer dans VLC. Existe-t-il d'autres options / logiciels pour copier les vidéos du caméscope? Je pourrais copier les fichiers et changer l'extension (ou non), mais sur le lecteur cible, chaque fichier m2ts contient trois autres fichiers (cont, pmpd, tmb), et je ne sais pas s'ils sont importants.
    Even with a fluent grasp of french, this doesn't make much sense... It looks like an automatic translation, but why would you auto-translate to french on an english speaking forum ?
    If you've seen those three other files, it means that the transfer worked, no ?
    To confirm that the files are indeed identical (as they should), size is not enough. You would need to check their CRC32 or MD5 checksum (with MD5Checker for instance), and/or compare them with an hexadecimal editor (HxD is free but rather limited, WinHex and HexWorkshop are commercial but have more features).
    Regarding those extra files, .tmb are simply JPG thumbnails, the other two I don't know, they seem to contain some kind of metadata, but I have no idea what is supposed to make use of them.
    As for the other options, the only one I could find so far is GH1Importer, which, despite its name, seems to work with other models ; it's stripped to the bones but apparently it does the job.
  2. Could the list of softwares proposed for download include versions of PhotoFunStudio which are not available on Panasonic's website ?
    For instance PhotoFunStudio 6.0 for the GH2...
    You can get your Panasonic Software from here:
    Who are you talking to ?
  3. Originally Posted by abolibibelot View Post
    Well, to all those who still try to find Panasonic HD Writer (and other Panasonic SW) throughout this thread, I guess. See the title of the thread.
  4. Well, to all those who still try to find Panasonic HD Writer (and other Panasonic SW) throughout this thread, I guess. See the title of the thread.
    Alright, but as you can see on the page you linked, several of those softwares are available as updates only, and the update won't work if you (general you) don't have the original complete software – unless I missed something – which is, I guess, why this thread was created in the first place...
  5. Originally Posted by abolibibelot View Post
    Alright, but as you can see on the page you linked, several of those softwares are available as updates only, ……..
    Oooops! You are right; I missed that
  6. Hi All,
    Using a HDC-SDT750 with HD Writer AE 2.6T. Will the latest version of HD Writer work with this camcorder? Ultimately, I would like to find a software bundle that can organize all my home video footage captured over the years. If anyone has any suggestions in this area I would greatly appreciate hearing about it! VideoRedo is mentioned quite a bit as an easy to use editing tool. Does it also provide the ability to organize videos? I suppose what I am looking for in this regard is a way to create a library of all my videos.
    Thanks in advance!
  7. Again, could someone please upload the install file for the complete PhotoFunStudio 6.0 BD Edition compatible with the Panasonic GH2 ?
    (Which may not even work for my camera as it's a european / “PAL” model... é_è But I found a simple Windows registry trick for the same PhotoFunStudio 3.0 install to deal with both a european / “PAL” Panasonic TZ7 and a non-european / “NTSC” ZS3, so I should be able to do the same with that one.)
  8. I have panasonic camera HDC-TM350. its software CD is lost i want HD writer AE 1.5. if any one have please share the link. My camera has software version 1. If any one have its update version then please share the link .
  9. Originally Posted by Tahir Maqsood View Post
    I would contact Panasonic Support. Maybe they send you a disc or an .iso of the software. The downloads are updates only:
    https://av.jpn.support.panasonic.com/support/global/cs/soft/download/index.html
    Alternatively you can merge and edit the .mts files in a (free) NLE. Drawback is that the files are getting re-encoded (no smart rendering), but the quality loss is hardly visible if you don't compress agressively or use a lossles or 'virtually lossless' codec.
  10. I contacted but did not get a reply.
    And my camera only supports SD card up to 32GB, will updating its software make it support more than 32GB card?
    Where can its software be downloaded?
    Mar 2008
    Australia
    I'm on holiday at the moment, DM me in Dec and I can sort out an ISO to download
    As for the 32gb ... Don't worry .. 128gb will work, it's just Panasonic guarantees 32gb will work
    Please get a FAST WRITE speed name brand U3 card, and you won't have any issues...
    I use Lexar x633 and x677 micro SD with adaptor
  12. Originally Posted by Grunta View Post
    Dear Grunta
    Thanks a lot for replying.
    I will wait for the iso file.
    I checked by inserting a Samsung 64GB SDXC card into the camera but the camera didn't read it.
    Then I inserted a Kodak 64GB SDXC card into the camera and checked, but it was also not read by the camera.
    My camera has software version 1. Maybe this is the reason. What version of software does your camera have? ?
    If you have updated software version for this camera, please upload that too.
    thank you
    Feb 2006
    Dear Grunta
    thank you
    did the camera not give the option to format the SD card ??
    when you insert the card in the camera, it should have an option to format
    the card before you can use it.
    Mar 2008
    Australia
    This is usually what happens - yes
    The software you're after is just the camera access and editing (?)
    Pretty sure no camera update, if there was a firmware update, you'd likely need to download it separately...
    That said, sometimes a software package does have an update option, which would connect to the Sony servers, but I don't recall this though....
    Even if mine had an update, doesn't mean yours will (I have the top model with the hard drive and SD card)
    Even my cheap actioncam says 32gb and reads 256gb
    I'd format it in your PC first, (don't use normal computer formatter) ...
    use fat32format free for download (right click and run as admin) ... Don't alter any settings
    Then if the camera offers to format the card, - do so
    Mar 2008
    Australia
    I'd format it in your PC first, use
    Did you notice this list of programs... as I'm travelling - I can't test a download.
    https://forum.videohelp.com/threads/349814-Panasonic-HD-Writer-software-no-download-An...e5#post2451297
  16. Originally Posted by Grunta View Post
    Thank you very much for replying.
    I formatted the 64GB card in FAT 32 using the software and inserted it into the camera, but the camera is not accepting it. Giving "Check Card" error.
    Where can I get the latest firmware of this camera?
    My camera's firmware is version 1. Maybe that's why it doesn't support cards above 32GB.
    Feb 2006
    see the pdf manual on SD card use - https://www.manualslib.com/manual/360811/Panasonic-Hdc-Tm350.html?page=19#manual see page 19 regular SD cards up to 2GB & SDHC cards up to 32 GB
  18. Member
    Mar 2008
    Australia
    @Tahir Maqsood
    Pretty sure my cam is HDC-HS900, so possibly more options, as mine also has a 200gb harddrive
    Did you click on the link in my past post ?
    It's a list of downloads.
    you could trying exfat as the format - no loss trying (afterwards... If it doesn't work use fat32format to redo the card)
    Often electronic devices list low capacity support
    USUALLY this isn't the maximum - just what they guarantee to work..
  19. Originally Posted by Grunta View Post
    @Tahir Maqsood
    I have already tried the exfat format ۔ camera is giving error even on exfat format?
    Mar 2008
    Australia
    @Tahir Maqsood
    unfortunately I can't find my CD - I don't use the program anyway - too clunky.
    this link from the other page works .... it is a later version - should work... why are you wanting it ?for the editing of the browser side ?
    you can just download directly from the folders, I can't remember exactly - but 1 of them is in the "\stream" folder - depends on the format you record in
    https://mega.co.nz/#!8koiyIpC!It1YaBfbWdhgDU8j5QR_NXg7kR0Ttek89Y4UQvJF5A8
