I've been using for a long time 'Media Player Classic' with k-lite codecs full.
I recently installed PotPlayer, and the picture I get with MPC/k-lite is much better (especially in flv files).
How do I set PotPlayer to use k-lite codecs?
I've read the folowing post. A detailed reply would be appreciated.
https://forum.videohelp.com/threads/346557-About-PotPlayer
Thank you.
Results 1 to 9 of 9
Try changing the video renderer. Preferences -> Video -> Video Renderer.
If you really think it's the internal codecs use Preferences -> Filter Control -> Source/Splitter and Video Decoder... -
Thanks for replying. I really appreciate it.
I'm using an old computer.
I've tried different settings, and the playback quality didn't get better.
I'll try some more. -
Thanks again.
This is the info I get when clicking on Video Renderer:
CLSID: {B87BEB7B-8D29-423F-AE4D-6582C10175AC}
Filter: Video Renderer
- Connected to:
CLSID: {04FE9017-F873-410E-871E-AB91661A4EF7}
Filter: ffdshow Video Decoder
Pin: Out
- Connection media type:
Video: YUY2 512x384 25.00fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 393216
cbFormat: 1152
VIDEOINFOHEADER:
rcSource: (0,0)-(512,384)
rcTarget: (0,0)-(512,384)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 400000
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 4
dwPictAspectRatioY: 3
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
BITMAPINFOHEADER:
biSize: 40
biWidth: 512
biHeight: -384
biPlanes: 1
biBitCount: 16
biCompression: YUY2
biSizeImage: 393216
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
And this is the info I get when clicking on ffdshow Video Decoder:
- Connected to:
CLSID: {1B544C20-FD0B-11CE-8C63-00AA0044B51E}
Filter: AVI Splitter
Pin: Stream 00
Video: XVID 512x384 25.00fps
AM_MEDIA_TYPE:
subtype: Unknown GUID Name {44495658-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 0
bTemporalCompression: 1
lSampleSize: 1
cbFormat: 88
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 512
biHeight: 384
biPlanes: 1
biBitCount: 12
biCompression: XVID
biSizeImage: 294912
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
I see the icon of ffdshow in the system tray.
How should I apply it to PotPlayer?
I hope it's not much of a trouble. I appreciate your help. -
That shows MPC is using ffdshow to decode the video. I don't recognize the video renderer but I think it's VMR7. If you can see the same renderer in PotPlayer select it. Disable the Built in Xvid and Divx decoders (set them to System Default). If you enable ffdshow's tray icon it will put its icon in the tray whenever it is in use. That's a good way to know if it's being used. You probably have to close PotPlayer and restart it for any of those changes to take effect.
Allow me to thank you again. I’ve read your last message a short while ago.
As you’ve suggested – I’ve set all Video Decoders to System default.
avi files: Both MPC and PotPlayer use ‘ffdshow Video Decoder’ with some files, and ‘WMVideo Decoder DMO’ with others. The playback quality seems to be the same.
mpg files: The playback quality is clearly better with MPC.
flv is more tricky: Clicking (MPC) Filters/ffdshow Video Decoder – the ‘Connection media type’ is sometimes ‘Video: MPEG4 Video (H264)’ (and then PotPlayer uses ffdshow), and sometimes ‘Video: Flash Video 1’ or ‘Video: FLV4’ (PotPlayer uses its internal Decoder, and the quality is not as good).
I’d be glad if you have the patience to devote some (more) thought to the matter.
Virtualdub and K-Lite Codec Pack
By EdoScario90 in forum Video ConversionReplies: 9Last Post: 9th Dec 2010, 15:26 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 13:12 -
Does K-Lite mega Pack support Nero 7?
By Djard in forum Software PlayingReplies: 37Last Post: 20th Sep 2010, 07:10 -
k-lite mega pack codecs 6.30 problems...
By sgbd in forum Software PlayingReplies: 10Last Post: 2nd Sep 2010, 04:46 -
Vista Codec Pack or K-Lite Codecs
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 13th Oct 2009, 19:07
