Whenever I capture at a resolution higher than 640x480 I get this odd bar at the bottom of the captures it takes up maybe the bottom 1/6 or 1/8 of the screen and has fluctuating colors in it. It does this with nearly all the codecs I can find : / Does anyone know what it is? I am using an AIT AIW 7500.
Thanks,
Mike[/img]
Are you capturing from vhs tape
XviD Encoded videos present distorted bar at the bottom
By deadp0et in forum Video ConversionReplies: 11Last Post: 4th Jul 2015, 09:45 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
Black bar on bottom of Windows Media Player 11
By Jynx980 in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 11:58 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 14:12 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 15:39
