I have a VHS-to-DVD video which for some reason somebody converted from 720 x 480i (29.97 fps) to progressive at some stage which lost half the temporal resolution. It's 5.7 Mbps but looks like crap. Is the quality lost or could I get any back by converting back to interlaced? I don't have the original video, this is all I have. Here's a clip.
Do I need any special filters or do I just do this to re-interlace it? I need to keep it 29.97 fps as Bluray doesn't support progressive 720 x 480 60 fps.
Code:AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
Besides all the other VHS problems (noise, damage etc...) You can try doubling the frames 29.97p => 59.94p (generating new inbetween frames) with motion interpolation (mvtools2, eg. interframe, svpflow, mflowfps) , the problems are edge morphing artifacts that can occur
You only need to re-interlace if you were going back to DVD (and you can't re-interlace it from a 29.97p source - it needs 59.94p) -
Is there any point in me going to 59.94 fps though as the video is going onto a Bluray and Bluray doesn't supports 720 x 480 at 59.94 fps so I need to keep it interlaced at 29.97 fps.
Yes, for SD blu-ray you would re-interlace it then
The question is how do you get 59.94 motion samples per sec before you re-interlace ?
The options are
1) duplicate frames - changefps(60000,1001)
2) blended frames - convertfps(60000,1001)
3) motion interpolation - one of the options listed above
They all have pros/cons. Option 3 produces the smoothest results, but at expense of edge morphing artifacts
You need to start with a 59.94p source before you reinterlace
Code:#59.94p source AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave()
Just encode the video interlaced. The encoder and the decoder don't care if the frames are progressive. Of course, it won't be as smooth as true 30i video. And the script you proposed in the first post would give you 15 fps, not 30 fps.
yes, if you just encode the 29.97p video as interlaced it would work. Visually it would give similar results to option (1) above
OK thanks. I will just encode as interlaced then like I usually do. Is there anything special which I should do to the video or will this script do to clean it up? Also should I have DegrainMedian on interlaced=true or not?
Code:Mpeg2Source("L:\2 = New\z = Encode\Raw December 23 2002 Fixed.d2v", CPU=6) RemoveSpots() DeGrainMedian(limitY=2, limitUV=3, mode=1, interlaced=true) Tweak(Bright=-0, Sat=0.8, Cont=1.0, Hue=20.0, Coring=False) Crop(0,0,-0,-16) AddBorders(0,8,0,8, $000000)Last edited by VideoFanatic; 2nd Oct 2012 at 16:03.
It will take a lot more than that script to "clean up" that video. But you may as well use it. IMHO there's not much you can do with it.
interlaced and progressive in same video. how to make only progressive.
By OmniShadow in forum Newbie / General discussionsReplies: 32Last Post: 19th Sep 2012, 00:44 -
slow motion by interlaced to progressive conversion?
By menczel in forum Video ConversionReplies: 9Last Post: 24th Apr 2011, 11:39 -
Conversion to Progressive Scan from Interlaced DV. Necessary?
By Anonymous4 in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 15:34 -
Converting 30fps Progressive to 25fps interlaced ? (Avisynth & VDub)
By blewyn in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 18:51 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48
