I`m trying to convert a friends episode by using the TMPGH software but get the message file is unsupported,I have divx codec installed.....
heelp.....
Use a program called Virtualdub (see the convert section or capture section to find it - its free). Convert the Divx to another decent type of AVI with a good codec (download Huffyuv codec for lossless conversion). Then TMPGenc will eat it up.
In TMPGenc option...environmental setting...vfapi plug-in...
Increase the priority if the Direct Show Multimedia File Reader until it is not a negative value (it's probably at -1 right now). Right click on it and choose "higher priority" until it is up to 0 (in the right column), then try and open your divx avi.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
thanks for the TMPGenc tip.....however all I got now was just sound,no picture??
I`m using divx5 with XP. -
I'm betting that TMPGenc's problem is with the sound, not the video...
Jeez, I give this advice often...
Anyway, open the .avi in VirtualDub, and save its audio as a .wav. Then, when you use TMPGenc, select the .avi as the video source and the .wav as the audio source.
Hi friends
By aditech in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2011, 04:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
Sending short videos to friends.
By Mark Wynn in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 12:08 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Friends desktop is blank
By andre477 in forum ComputerReplies: 2Last Post: 24th May 2007, 06:44
