Results 1 to 10 of 10
Heh, my source videos are MP4 videos filmed with a camcorder, they don't have subtitles. And in handbrake i can only import SRT subtitles, but they cannot burned in. I need to add SSA submitles, but i cannot import them. Any ideas how to import them?
I have read that i would need to remux the videos to MKV and mux SSA into them. But it would be lot of time to remux all my collection
Any other suggestions? -
step up to some GUI front-end x264 encoder with Avisynth support
Decent in what sense, easy to use ? You can start with Ripbot264 for example check how Avisynth works, these things will liberate you in a sense.
Here is the thing , you can feed encoder with a Avisynth script (something.avs), author(s) of Handbrake refuses to implement it, maybe it is not possible for that program. That script takes care of loading your video and you can add some lines in that script that fix or add something to it (fixing levels, logo, image with alpha channel, top quality deinterlace etc, it is up to you). -
I would try the new video to video converter. It can convert everything to everything and it's free. Under settings->watermark can you load an image for watermarking your video.
(It is a gui for ffmpeg and some other free tools)
.tp to mp4 using handbrake
By losernoob in forum Video ConversionReplies: 0Last Post: 25th Sep 2012, 12:05 -
Is there a program similar to TMPGEnc for .mp4 and .mkv files?
By Shinjikun in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2012, 15:15 -
Need suggestion: free software for MP4 cropping, clipping, & watermarking?
By avideodummy in forum EditingReplies: 2Last Post: 20th Jan 2012, 10:52 -
Software to join .ts(avchd) and .mp4 video files without re-encoding
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Oct 2010, 11:07 -
Looking for a video editing feature similar to "Shadows/Highlights" from PS
By vitwa in forum EditingReplies: 5Last Post: 6th Mar 2010, 18:21
